Help! Problem output using jdbc input
Hello! i'm using jdbc input to access my first Mysql data, my schedule is around 30 minutes, after that i'm using jdbc streaming to upload an other database , then i use simple output to see my data as stdout ruby , the problem is that the process is very slow and after running it in mode debug i see my first statement and after 20 minutes the same statement again and i have nothing in my output
I have removed the schedule, even though after 10 minutes the statement of my first database is repeating , please help
Start by posting your Logstash configuration.
jdbc {
jdbc_driver_library => "/etc/logstash/mysql-connector-java-5.1.36.jar"
jdbc_driver_class => "com.mysql.jdbc.Driver"
jdbc_connection_string => "jdbc:mysql:*"
jdbc_validate_connection => true
jdbc_user => "
jdbc_password => "*****"
jdbc_paging_enabled => "true"
jdbc_page_size => "50000"
#schedule => "
/40 * * * *"
statement => "SELECT id1, id2, Id3, id4 from base1 where id3 > :sql_last_value AND id2 REGEXP '' order by id1 ASC Limit 1000"
record_last_run => "true"
use_column_value => "true"
tracking_column => "id2"
tracking_column_type => "numeric"
clean_run => "false"
last_run_metadata_path => "/etc/logstash/.logstash_jdbc_last_run"
type => "base"
date {
match => [ "id2","UNIX_MS" ]
target => "@timestamp"
mutate {
replace => { "id2" => "%{@timestamp}" }
lowercase => ["id2"]
jdbc_streaming {
jdbc_driver_library => "/etc/logstash/mysql-connector-java-5.0.8-bin.jar"
jdbc_user => "
jdbc_password => "
statement => "SELECT `` From base2
parameters => {"variable"=>""}
target => ""
cache_expiration => 43200.0
cache_size => 520000
split {
field =>""
alter {
coalesce => ["" , "%{[][]}"]
mutate {
remove_field => [""]
stdout {codec => rubydebug}
Okay. So you're saying that every 10 minutes the query in your jdbc input is run and produces a number of events, even though the schedule option is clearly commented out? Have you checked that you don't have any extra files in /etc/logstash/conf.d that Logstash might be reading?
