Help with data management, I have an index with a size of 119GB, what can I do?
I have an index with a size of 119GB that is causing performance issues when search the data.
My first thought was to use an index policy to expire old documents but soon I learned the lifecycle policy only works for the new documents of that index, is that right?
I used time series (@timestamp) and I would like to:
  1. Delete documents older than 3 months.
  2. Break/shrink into 40GB small chunks the data left in the index after expiring the old documents
I don't even know where to start. Help please!!!
ILM works on indices, not on documents. So if you are using time based events/documents, you should use time based indices and then ILM :slight_smile:
