Hi Jorg,
Thanks for the response.  I don't actually need to model the relationship
per se, more that a document is used in a relationship via a filter, then
search on it's properties.  See the example below for more clarity.
Restaurant: => {name: "duo"}
Now, lets say I have 3 users,
George, Dave and Rod
George Dave and Rod all "like" the restaurant Duo.  These are directed
edges from the user, of type "likes" to the "duo" document.  We store these
edges in Cassandra.  Envision the document looking something like this.
openTime: 9,
closeTime: 18
_in_edges: [ "george/likes", "dave/likes", "rod/likes" ]
Then when searching, the user Dave would search something like this.
select * where closeTime < 16
Which we translate in to a query, which is then also filtered by _in_edges
= "dave/likes".
Our goal is to only create 1 document per node in our graph (in this
example restaurant), then possibly use the scripting API to add and remove
elements to the _in_edges fields and update the document.  My only concern
around this is document size.  It's not clear to me how to go about this
when we start getting millions of edges to that same target node, or
_in_edges field could grow to be millions of fields long.  At that point,
is it more efficient to de-normalize and just turn "dave/likes",
"rod/likes", and "george/likes" into document types and store multiple
copies?
Thanks,
Todd
On Sat, Oct 4, 2014 at 2:52 AM, joergprante@gmail.com <joergprante@gmail.com
wrote:
Not sure if this helps but I use a variant of graphs in ES, it is called
Linked Data (JSON-LD)
By using JSON-LD, you can index something like
doc index: graph
doc type: relations
doc id: ...
"user" : {
"id" : "...",
"label" : "Bob",
"likes" : "restaurant:Duo"
for the statement "Bob likes restaurant Duo"
and then you can run ES queries on the field "likes" or better
"user.likes" for finding the users that like a restaurant etc. Referencing
the "id" it is possible to lookup another document in another index about
"Bob".
Just to give an idea how you can model relations in structured ES JSON
objects.
Jörg
On Fri, Oct 3, 2014 at 7:59 PM, Todd Nine tnine@apigee.com wrote:
So clearly I need to RTFM.  I missed this in the documentation the first
time.
Elasticsearch Platform — Find real-time answers at scale | Elastic
Will filters at this scale be fast enough?
On Friday, October 3, 2014 11:48:40 AM UTC-6, Todd Nine wrote:
Hey guys,
We're currently storing entities and edges in Cassandra.  The entities
are JSON, and edges are directed edges with a source---type-->target.
We're using Elasticsearch for indexing and I could really use a hand with
design.
What we're doing currently, is we take an entity, and turn it's JSON
into a document.  We then create multiple copies of our document and change
it's type to match the index.  For instance, Image the following use case.
bob(user) -- likes -- > Duo (restaurant)   ===> Document Type  =
bob(user) + likes + restaurant ; bob(user) + likes
bob(user) -- likes -> Root Down (restaurant)  ===> Document Type  =
bob(user) + likes+ restaurant ; bob(user) + likes
bob(user) -- likes --> Coconut Porter (beer). ===> Document Types =
bob(user) + likes + beer; bob(user) + likes
When we index using this scheme we create 3 documents based on the
restaurants Duo and Root Down, and the beer Coconut Porter.  We then store
this document 2x, one for it's specific type, and one in the "all" bucket.
Essentially, the document becomes a node in the graph.  For each
incoming directed edge, we're storing 2x documents and changing the type.
This gives us fast seeks when we search by type, but a LOT of data bloat.
Would it instead be more efficient to keep an array of incoming edges in
the document, then add it to our search terms?  For instance, should we
instead have a document like this?
docId: Duo(restaurant)
edges: [ "bob(user) + likes + restaurant", "bob(user) + likes" ]
When searching where edges = "bob(user) + likes + restaurant"?
I don't know internally what specifying type actually does, if it just
treats it as as field, or if it changes the routing of the response?    In
a social situation millions of people can be connected to any one entity,
so we have to have a scheme that won't fall over when we get to that case.
Any help would be greatly appreciated!
Thanks,
Todd
"elasticsearch" group.
email to elasticsearch+unsubscribe@googlegroups.com.
To view this discussion on the web visit
https://groups.google.com/d/msgid/elasticsearch/f97c6475-f4fc-4078-b052-b497ac82dc91%40googlegroups.com
https://groups.google.com/d/msgid/elasticsearch/f97c6475-f4fc-4078-b052-b497ac82dc91%40googlegroups.com?utm_medium=email&utm_source=footer
You received this message because you are subscribed to a topic in the
Google Groups "elasticsearch" group.
To unsubscribe from this topic, visit
https://groups.google.com/d/topic/elasticsearch/wtKQYcpb1-A/unsubscribe.
To unsubscribe from this group and all its topics, send an email to
https://groups.google.com/d/msgid/elasticsearch/CAKdsXoF0jKYVLKNV7RDjTCqsKnzjQmjZb%2BxBpkkGPa3YAHfM6A%40mail.gmail.com
https://groups.google.com/d/msgid/elasticsearch/CAKdsXoF0jKYVLKNV7RDjTCqsKnzjQmjZb%2BxBpkkGPa3YAHfM6A%40mail.gmail.com?utm_medium=email&utm_source=footer
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CA%2Byzqf9pw2YMtFDqjcH3QejL%3DF04dZVUaw1j5Jt8Nrd%3DxX3ZPw%40mail.gmail.com.
