My folder structure is as follows:
main_directory.
| .env
| docker-compose.yml
+---elasticsearch
| \---config
| elasticsearch.yml
\---logstash
+---config
| | logstash.yml
| | pipelines.yml
| \---pipeline
| logstash.conf
+---data
| | .lock
| | dummy.csv
| | test.csv
| | uuid
| +---dead_letter_queue
| \---queue
\---logs
My logstash.conf is as follows:
file {
path => "/usr/share/logstash/data/*.csv"
start_position => "beginning"
sincedb_path => "/dev/null"
csv {
separator => ","
# columns => ["User_Id","First_Name"]
autodetect_column_names => true
skip_header => true
dissect{
mapping => {
"path" => "/usr/share/logstash/data/#%{file_name}.csv"
hosts => "${ELASTICSEARCH_HOST}"
user => "${ELASTICSEARCH_USERNAME}"
password => "${ELASTICSEARCH_PASSWORD}"
index => "my_index_prime_%{file_name}"
ssl => true
ssl_certificate_verification => false
manage_template => false
Inside the /data/ directory there are many csv like test.csv, sample.csv, work_index_one.csv etc.
I used dissect in filter to add filenames to my index in the format of my_index_prime_${file_name} but I got the patternNotFound error:
[2023-05-17T19:38:16,515][WARN ][org.logstash.dissect.Dissector][main][3b3f27d0e8ab71d66a5d2b9d3b16693ce141224b733810c11fea3544cb5beef7] Dissector mapping, pattern not found {"field"=>"path", "pattern"=>"/usr/share/logstash/data/#%{file_name}.csv", "event"=>{"tags"=>["_dissectfailure"], "@version"=>"1", "message"=>"002,Asif\r", "path"=>"/usr/share/logstash/data/dummy.csv", "First_Name"=>"Asif", "@timestamp"=>2023-05-17T19:38:16.308Z, "host"=>"f47d5a099289", "User_Id"=>"002"}}
Any advice would be highly appreciated!
I'm trying to dynamically append file name to my index
