i have elasticsearch kibana and elastic-agent installed ok.
but elastic-agent not work in kibana, I ALWAYS SAY LISTENING FOR AGENT WHEN I GO TO CLICK ADD AGENT. IN STEP 3 IN INTEGRATION POLICIE CONFIRM AGENT ENROLLMENT, I AM TRYING TO INSTALL SURICATA HERE IN KIBANA BUT I AM NOT SUCCESSFUL, ON PC IT IS WORKING.
sudo systemctl status elasticsearch
● elasticsearch.service - Elasticsearch
Loaded: loaded (/lib/systemd/system/elasticsearch.service; enabled; vendor>
Active: active (running) since Wed 2023-01-04 10:57:24 WET; 3h 24min ago
Docs: https://www.elastic.co
Main PID: 28810 (java)
Tasks: 93 (limit: 9240)
Memory: 4.2G
CPU: 23min 43.690s
CGroup: /system.slice/elasticsearch.service
├─28810 /usr/share/elasticsearch/jdk/bin/java -Xms4m -Xmx64m -XX:+>
├─28870 /usr/share/elasticsearch/jdk/bin/java -Des.networkaddress.>
└─28892 /usr/share/elasticsearch/modules/x-pack-ml/platform/linux->
sudo systemctl status kibana
● kibana.service - Kibana
Loaded: loaded (/lib/systemd/system/kibana.service; enabled; vendor preset>
Active: active (running) since Wed 2023-01-04 09:02:14 WET; 5h 19min ago
Main PID: 1186 (node)
Tasks: 11 (limit: 9240)
Memory: 314.4M
CPU: 11min 3.376s
CGroup: /system.slice/kibana.service
└─1186 /usr/share/kibana/bin/../node/bin/node /usr/share/kibana/bi>
sudo systemctl status elastic-agent
● elastic-agent.service - Elastic Agent is a unified agent to observe, monitor >
Loaded: loaded (/etc/systemd/system/elastic-agent.service; enabled; vendor>
Active: active (running) since Wed 2023-01-04 09:01:31 WET; 5h 20min ago
Main PID: 854 (elastic-agent)
Tasks: 79 (limit: 9240)
Memory: 229.7M
CPU: 13min 55.694s
CGroup: /system.slice/elastic-agent.service
├─ 854 /opt/Elastic/Agent/elastic-agent
├─ 1120 /opt/Elastic/Agent/data/elastic-agent-0e1a73/install/fileb>
├─ 1181 /opt/Elastic/Agent/data/elastic-agent-0e1a73/install/metri>
├─ 1199 /opt/Elastic/Agent/data/elastic-agent-0e1a73/install/fileb>
├─ 1220 /opt/Elastic/Agent/data/elastic-agent-0e1a73/install/metri>
└─28982 /opt/Elastic/Agent/data/elastic-agent-0e1a73/install/fleet>
