Help with RUBY. Recognising field with prefix and changing its type
Hi, I am trying to convert fields with a certain prefix into an integer
      event.to_hash.keys.each { |k|
    if event.get[k].is_a?(String) and k.start_with?('behaviour_' || 'top_disease_')
      event.get[k] = event.set[k].to_i
    end
Ideally I want to check prefix (for behaviour or top_disease) and then whether its a string.
I also found another post about this code structure; but it does not work either
    code => "event.set(k, v.to_f) if k.start_with?('behaviour_' || 'top_disease_')"
I have modified the RUBY code as under:
  ruby {
code => "
    if event.get[k].start_with?('behaviour_' || 'top_disease_') and k.is_a?(String)
    end
By doing this, I am getting the following error:
Ruby exception occurred: wrong number of arguments calling 'get' <0 for 1>
Another try:
  ruby {
code => "
    if event[k].start_with?('behaviour_' || 'top_disease_') and k.is_a?(String)
      event.set[k].to_i
    end
I think your issue may come from the use of event.get/set functions :
ruby {
  code => "
      if event.get(k).start_with?('behaviour_' || 'top_disease_') and k.is_a?(String)
        event.get(k) = event.set(k, k.to_i)
      end
There are over 50 fields... I have tried the mutate filter to convert them into integer. With the filter, it works. Further, these fields are created dynamically -- so the additions can be on-the-fly taking them to more than 50 in the near future. Is there any documentation about using the ruby plugin? The ruby-filter plugin guidelines are not very clear. I am unable to understand the get/set stuff.
There is another similar query but it is unresolved.
Yes I figured, this is why I have edited my answer and put my question back :yum:
Have you tried my solution ?
I tried it but it gives an unexpected "=" error in
my bad, try this :
ruby {
  code => "
        event.set(k, event.get(k).to_i)
      end
I think now we are getting somwhere.. I got the following error:
Ruby exception occurred: undefined method `start_with?' for nil:NilClass
I tried removed || with a , but it did not work and I got the same error.
ruby {
code => "
if event.get(k).start_with?('behaviour_' , 'top_disease_')
end
try this :
ruby {
  code => "
      if ( event.get(k).start_with?('behaviour_') || event.get(k).start_with?('top_disease_') )
      end
or
ruby {
  code => "
      event.get(k).match('(behaviour|top_disease)_.*') {
Still the undefined error for both start_with and match
any other ideas?
Hi Jainh, could you give us a sample event ?
Because the error let me think that your fields 'behaviour_' or 'top_disease_' are empty ... cf. Event API | Logstash Reference [8.11] | Elastic
Get API
The getter is a read-only access of field-based data in an Event.
Syntax: event.get(field)
Returns: Value for this field or nil if the field does not exist. Returned values could be a string, numeric or timestamp scalar value.
Remove your filter and print the output with
  stdout {}
