How add field on index according to another value in same index
Hello, everyone,
I am working on an elastic index.
I would like to add a 'status' field that is equal to 'success' if the 'code' field is equal to 0, or the 'status' field is 'fail' if the 'code' field is different from 0.
I would like to do this automatically with the arrival of my logs. I tried with a processor in ingest pipeline but failed.
Could someone give me a hand?
Hi @DVD_MNC
Something like this
PUT _ingest/pipeline/discuss_test
  "processors": [
      "set": {
        "if": "ctx.code == 0",
        "field": "status",
        "value": "success"
      "set": {
        "if": "ctx.code != 0",
        "field": "status",
        "value": "fail"
POST _ingest/pipeline/discuss_test/_simulate
  "docs": [
      "_source": {
        "code": 0
      "_source": {
        "code": 1
      "_source": {
        "code": 3
      "_source": {
        "code": -1
# Result
  "docs": [
      "doc": {
        "_index": "_index",
        "_id": "_id",
        "_version": "-3",
        "_source": {
          "code": 0,
          "status": "success"
        "_ingest": {
          "timestamp": "2023-10-26T04:01:33.030899373Z"
      "doc": {
        "_index": "_index",
        "_id": "_id",
        "_version": "-3",
        "_source": {
          "code": 1,
          "status": "fail"
        "_ingest": {
          "timestamp": "2023-10-26T04:01:33.030925393Z"
      "doc": {
        "_index": "_index",
        "_id": "_id",
        "_version": "-3",
        "_source": {
          "code": 3,
          "status": "fail"
        "_ingest": {
          "timestamp": "2023-10-26T04:01:33.030933593Z"
      "doc": {
        "_index": "_index",
        "_id": "_id",
        "_version": "-3",
        "_source": {
          "code": -1,
          "status": "fail"
        "_ingest": {
          "timestamp": "2023-10-26T04:01:33.030939827Z"
Thanks for response. I solved. Thank you so much!
