How can I solve turkish letter issue in elasticsearch by using C# nest?
0
down vote
favorite
In Turkey, we have Turkish letters like 'ğ', 'ü', 'ş', 'ı', 'ö', 'ç'. But when we search generally we use the letters 'g', 'u', 's', 'i', 'o', 'c'. This is not a rule but we generally do it, think like a habit, something we used to. Forexample if i write camelcase "Ş" it should be searched "ş" and "s". Look please this link it is the same thing. But Their solution is too long and not perfect. How can i below thing?
My goal is this:
ProductName or Category.CategoryName may contain Turkish letters ("Eşarp") or some may be mistyped and written with English letters ("Esarp") Querystring may contain Turkish letters ("eşarp") or not ("esarp") Querystring may have multiple words Every indexed string field should be searched against querystring (full-text search)
indexing and full text searching in elasticsearch without dialitics using c# client Nest
My Code is :
using Nest;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace ElasticSearchTest2
class Program
public static Uri EsNode;
public static ConnectionSettings EsConfig;
public static ElasticClient client;
static void Main(string[] args)
EsNode = new Uri("http://localhost:9200/");
EsConfig = new ConnectionSettings(EsNode);
client = new ElasticClient(EsConfig);
        var partialName = new CustomAnalyzer
            Filter = new List<string> { "lowercase", "name_ngrams", "standard", "asciifolding" },
            Tokenizer = "standard"
        var fullName = new CustomAnalyzer
            Filter = new List<string> { "standard", "lowercase", "asciifolding" },
        client.CreateIndex("indexname", c => c
                        .Analysis(descriptor => descriptor
                            .TokenFilters(bases => bases.Add("name_ngrams", new EdgeNGramTokenFilter
                                MaxGram = 20,
                                MinGram = 2,
                                Side = "front"
                            .Analyzers(bases => bases
                                .Add("partial_name", partialName)
                                .Add("full_name", fullName))
                        .AddMapping<Employee>(m => m
                            .Properties(o => o
                                .String(i => i
                                    .Name(x => x.Name)
                                    .IndexAnalyzer("partial_name")
                                    .SearchAnalyzer("full_name")
        Employee emp = new Employee() { Name = "yılmaz", SurName = "eşarp" };
        client.Index<Employee>(emp, idx => idx.Index("employeeindex7"));
        Employee emp2 = new Employee() { Name = "ayşe", SurName = "eşarp" };
        client.Index<Employee>(emp2, idx => idx.Index("employeeindex7"));
        Employee emp3 = new Employee() { Name = "ömer", SurName = "eşarp" };
        client.Index<Employee>(emp3, idx => idx.Index("employeeindex7"));
        Employee emp4 = new Employee() { Name = "gazı", SurName = "emir" };
        client.Index<Employee>(emp4, idx => idx.Index("employeeindex7"));
public class Employee
    public string Name { set; get; }
    public string SurName { set; get; }
My Search Query:
namespace Atom.Customer.Service
public class SearchCustomerService
: CustomerModuleServiceBase<SearchCustomerRequestEntity, SearchCustomerResponseEntity>
[MainMethod("1.0")]
public SearchCustomerResponseEntity MainMethodV1(SearchCustomerRequestEntity searchCustomerPhrase)
var searchCustomerResponse = new SearchCustomerResponseEntity();
var elasticClient = new ElasticSearchClient();
var client = elasticClient.GetClient("employeeindex7");
var searchResults = client.Search(s => s
.AllTypes()
.From(0)
.Size(10)
.Query(q => q.Bool(p => p.Must((m => m
.QueryString(qs => qs
.DefaultField("_all")
.Query(searchCustomerPhrase.Query))))))
searchCustomerResponse.TotalCount = searchResults.HitsMetaData.Total;
searchCustomerResponse.Customers = searchResults.Hits.Select(h => h.Source).ToList();
return searchCustomerResponse;
Take a look at
Incorporating a token filter that performs character folding into an analyzer will solve your problem.
By default, a querystring query runs against the "_all" field, which contains the concatenation of all string fields within the document. You can change the field(s) that this query runs against, and can create your own _all-like fields with copy_to to have control over what fields get included.
