For example i want below searching with this string "we added a large" string from the (paragraph and subject ) fields, and paragraph contain this string below
"We encountered elevated H2S levels today in the trailer, we added a large fan from Caleb. We think the lower end of the hose is not adequately sealed to the tank. ."
"only when the lid comes off during cleaning/rinsing. Caleb suggested beefing up the fan, we can look at this. We are also going to modify our large procedures to use clean water from"
first paragaph which have complete match string should be on first and then other matches should be on second priorty
