Issue description
now,I want select es using 'spark-sql',but 'predicate pushdown' does not take effect
Description
Steps to reproduce
Code:
first I create a index
curl -H "Content-Type: application/json" -XPOST 'http://localhost:9200/myindex/_mapping?pretty=true' -d '
"properties": {
"author" : {
"type" : "text",
"analyzer": "ik_max_word",
"search_analyzer": "ik_max_word",
"fields": {
"raw": {
"type": "keyword"
"name" : {
"type" : "text",
"fields": {
"raw": {
"type": "keyword"
"uuid" : {
"type" : "keyword"
and create a global_temp table in spark
val conf = new SparkConf().setMaster("local").setAppName("sss").set("es.nodes", "countly-new002").set("es.port", "9200").set("pushdown", "true")
val spark = SparkSession.builder().master("local[*]").appName("spark_es").config(conf).enableHiveSupport().getOrCreate()
var df = spark.read.format("org.elasticsearch.spark.sql").options(Map("es.nodes" -> "countly-new002", "es.port" -> "9200", "es.resource" -> "myindex", "es.index.auto.create" -> "false", "pushdown" -> "true", "strict" -> "false")).load();
df.createOrReplaceGlobalTempView("myindex")
HiveThriftServer2.startWithContext(spark.sqlContext)
when I search data from ES using spark-sql:
select * from global_temp.myindex where name = '慕容公子' limit 10;
| author | name | uuid |
explain select * from global_temp.myindex where name = '慕容公子' limit 10;
| == Physical Plan ==
CollectLimit 10
+- *(1) Filter (isnotnull(name#1) && (name#1 = 慕容公子))
+- *(1) Scan ElasticsearchRelation(Map(es.internal.spark.sql.pushdown -> true, es.index.auto.create -> false, es.port -> 9200, es.resource -> myindex, es.nodes -> countly-new002, es.internal.spark.sql.pushdown.strict -> false),org.apache.spark.sql.SQLContext@2fc0ad21,None) [author#0,name#1,uuid#2] PushedFilters: [IsNotNull(name), EqualTo(name,慕容公子)], ReadSchema: struct<author:string,name:string,uuid:string>
the PushedFilters are '[IsNotNull(name), EqualTo(name,慕容公子)]'
and 'es.internal.spark.sql.pushdown.strict' is false.
| SQL syntax | ES 1.x/2.x syntax | ES 5.x syntax |
| = null , is_null | missing | must_not.exists |
| = (strict) | term | term |
| = (not strict) | match | match |
| > , < , >= , ⇐ | range | range |
| is_not_null | exists | exists |
| in (strict) | terms | terms |
| in (not strict) | or.filters | bool.should |
| and | and.filters | bool.filter |
| or | or.filters | bool.should [bool.filter] |
| not | not.filter | bool.must_not |
| StringStartsWith | wildcard(arg*) | wildcard(arg*) |
| StringEndsWith | wildcard(*arg) | wildcard(*arg) |
| StringContains | wildcard(arg) | wildcard(arg) |
| EqualNullSafe (strict) | term | term |
| EqualNullSafe (not strict) | match | match |
that should execute 'match' in es , but not.
when I execute 'match' with eql is
select * from myindex where match(name,'慕容公子') limit 10;
author|name|uuid
金庸| 纷纷猜测是慕容公子与小姐外出踏青了。|1c5249c4-91a1-11ea-ac36-00163e014c29
using spark-sql
select * from global_temp.myindex where match(name,'慕容公子') limit 10;
Error: org.apache.spark.sql.AnalysisException: Undefined function: 'match'. This function is neither a registered temporary function nor a permanent function registered in the database 'default'.; line 1 pos 41 (state=,code=0)
the log file of debug is
2020-05-12 18:23:34 DEBUG HttpConnection:692 - Open connection to 10.160.15.251:9200
2020-05-12 18:23:34 DEBUG header:70 - >> "POST /library/_search?sort=_doc&scroll=5m&size=2&preference=_shards%3A0%7C_local&track_total_hits=true HTTP/1.1[\r][\n]"
2020-05-12 18:23:34 DEBUG HttpMethodBase:1352 - Adding Host request header
2020-05-12 18:23:34 DEBUG header:70 - >> "Content-Type: application/json[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - >> "Accept: application/json[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - >> "User-Agent: Jakarta Commons-HttpClient/3.1[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - >> "Host: 10.160.15.251:9200[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - >> "Content-Length: 168[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - >> "[\r][\n]"
2020-05-12 18:23:34 DEBUG content:84 - >> "{"query":{"bool":{"must":[{"match_all":{}}],"filter":[{"exists":{"field":"name"}},{"match":{"name":"Wakes"}}]}},"_source":["author","name","page_count","release_date"]}"
2020-05-12 18:23:34 DEBUG EntityEnclosingMethod:508 - Request body sent
2020-05-12 18:23:34 DEBUG header:70 - << "HTTP/1.1 200 OK[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - << "content-type: application/json; charset=UTF-8[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - << "content-length: 566[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - << "[\r][\n]"
2020-05-12 18:23:34 DEBUG content:84 - << "{"_scroll_id":"DXF1ZXJ5QW5kRmV0Y2gBAAAAAAAAAPcWLTZ0SktUdXRSWkNvYUVONkNsNVBqZw==","took":1,"timed_out":false,"_shards":{"total":1,"successful":1,"skipped":0,"failed":0},"hits":{"total":{"value":3,"relation":"eq"},"max_score":null,"hits":[{"_index":"library","_type":"book","_id":"Leviathan Wakes","_score":null,"_source":{"release_date":"2011-06-02","author":"James S.A. Corey","name":"Leviathan Wakes","page_count":561},"sort":[0]},{"_index":"library","_type":"book","_id":"FidoCHIBfHIo0bf8rilh","_score":null,"_source":{"author":"a","name":"Wakes 1"},"sort":[3]}]}}"
2020-05-12 18:23:34 DEBUG HttpMethodBase:1024 - Resorting to protocol version default close connection policy
2020-05-12 18:23:34 DEBUG HttpMethodBase:1028 - Should NOT close connection, using HTTP/1.1
2020-05-12 18:23:34 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
2020-05-12 18:23:34 DEBUG HeaderProcessor:174 - Added HTTP Headers to method: [Content-Type: application/json
, Accept: application/json
2020-05-12 18:23:34 DEBUG CommonsHttpTransport:642 - Using regular user provider to wrap rest request
2020-05-12 18:23:34 DEBUG UserGroupInformation:1722 - PrivilegedAction as:admin (auth:SIMPLE) from:org.elasticsearch.hadoop.mr.security.HadoopUser.doAs(HadoopUser.java:66)
2020-05-12 18:23:34 DEBUG header:70 - >> "POST /_search/scroll?scroll=5m HTTP/1.1[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - >> "Content-Length: 80[\r][\n]"
2020-05-12 18:23:34 DEBUG content:84 - >> "{"scroll_id":"DXF1ZXJ5QW5kRmV0Y2gBAAAAAAAAAPcWLTZ0SktUdXRSWkNvYUVONkNsNVBqZw=="}"
2020-05-12 18:23:34 DEBUG header:70 - << "content-length: 396[\r][\n]"
2020-05-12 18:23:34 DEBUG content:84 - << "{"_scroll_id":"DXF1ZXJ5QW5kRmV0Y2gBAAAAAAAAAPcWLTZ0SktUdXRSWkNvYUVONkNsNVBqZw==","took":1,"timed_out":false,"terminated_early":false,"_shards":{"total":1,"successful":1,"skipped":0,"failed":0},"hits":{"total":{"value":3,"relation":"eq"},"max_score":null,"hits":[{"_index":"library","_type":"book","_id":"FydoCHIBfHIo0bf8rilh","_score":null,"_source":{"author":"b","name":"Wakes 2"},"sort":[4]}]}}"
2020-05-12 18:23:34 DEBUG header:70 - << "content-length: 265[\r][\n]"
2020-05-12 18:23:34 DEBUG content:84 - << "{"_scroll_id":"DXF1ZXJ5QW5kRmV0Y2gBAAAAAAAAAPcWLTZ0SktUdXRSWkNvYUVONkNsNVBqZw==","took":1,"timed_out":false,"terminated_early":false,"_shards":{"total":1,"successful":1,"skipped":0,"failed":0},"hits":{"total":{"value":3,"relation":"eq"},"max_score":null,"hits":[]}}"
2020-05-12 18:23:34 DEBUG header:70 - >> "DELETE /_search/scroll HTTP/1.1[\r][\n]"
2020-05-12 18:23:34 DEBUG header:70 - >> "Content-Length: 82[\r][\n]"
2020-05-12 18:23:34 DEBUG content:84 - >> "{"scroll_id":["DXF1ZXJ5QW5kRmV0Y2gBAAAAAAAAAPcWLTZ0SktUdXRSWkNvYUVONkNsNVBqZw=="]}"
2020-05-12 18:23:34 DEBUG header:70 - << "content-length: 32[\r][\n]"
2020-05-12 18:23:34 INFO Executor:54 - Finished task 0.0 in stage 2.0 (TID 2). 1337 bytes result sent to driver
2020-05-12 18:23:34 DEBUG TaskSchedulerImpl:58 - parentName: , name: TaskSet_2.0, runningTasks: 0
2020-05-12 18:23:34 INFO TaskSetManager:54 - Finished task 0.0 in stage 2.0 (TID 2) in 32 ms on localhost (executor driver) (1/1)
I can know that the api of '_search/scroll' returned data in the log
but the data returned from sparksql is nothing.
Version Info
OS: : centos7
JVM : jdk1.8
Hadoop/Spark: spark 2.3.2
ES-Hadoop : elasticsearch-hadoop-7.6.2
ES : elasticsearch 7.6.2
How search es using spark-sql with 'function match' or can I execute 'match' using spark-sql with other ways?thk.
