How to Add Data into Existing Index in Elasticsearch 6.4.3 using Olivere Package in Golang
I am not sure whether it is correct or not. But I think that if I want to add new data or document into existing index in elasticsearch using olivere in golang, the only option available is to delete the index and re index the data.
This is my code :
package main
import (
	"context"
	"errors"
	"github.com/olivere/elastic"
const (
	indexName    = "newera"
	docType      = "log"
	appName      = "myApp"
	indexMapping = `{
     "mappings" : {
		"log" : {
		  "properties" : {
			"category_id" : {
			  "type" : "text"
type Log struct {
	CategoryID string `json:"category_id"`
func main() {
	client, err := elastic.NewClient(elastic.SetURL("http://localhost:9200"))
	if err != nil {
		panic(err)
	err = createIndexWithLogs(client)
	if err != nil {
		panic(err)
	// err = findAndPrintAppLogs(client)
	// if err != nil {
	// 	panic(err)
func createIndexWithLogs(client *elastic.Client) error {
	exists, err := client.IndexExists(indexName).Do(context.Background())
	if err != nil {
		return err
	if exists {
		client.DeleteIndex(indexName).Do(context.Background())
	res, err := client.CreateIndex(indexName).Body(indexMapping).Do(context.Background())
	if err != nil {
		return err
	if !res.Acknowledged {
		return errors.New("CreateIndex was not acknowledged. Check that timeout value is correct.")
	return addLogsToIndex(client)
func addLogsToIndex(client *elastic.Client) error {
	for i := 0; i < 10; i++ {
		l := Log{
			CategoryID: "New Worlds",
		_, err := client.Index().
			Index(indexName).
			Type(docType).
			BodyJson(l).
		if err != nil {
			return err
	return nil
Does anyone have a solution?
I am pretty sure that this is not the case, knowing Oliver (but not the go client) :slight_smile:
I am not sure, if he is reading here, so maybe asking this question in the github repo from the client is appropriate and might lead to a more concrete answer.
