How to alter GET /index/_mapping output to work with PUT /index/_mapping
I am upgrading elasticsearch from 2.x to 7.x. I am trying to re-add index mappings from 2.x. I want to know how to alter a mapping to make it compatible with 7.x.
Here is the result of GET /syslog/_mapping from 2.x
	"syslog": {
		"mappings": {
			"syslog": {
				"properties": {
					"@timestamp": {
						"type": "date",
						"format": "dateOptionalTime"
					"@version": {
						"type": "string"
					"_index": {
						"type": "string"
					"_type": {
						"type": "string"
					"file": {
						"type": "string"
					"host": {
						"type": "string"
					"message": {
						"type": "string"
					"offset": {
						"type": "string"
					"received_at": {
						"type": "date",
					"received_from": {
						"type": "string"
					"syslog_facility": {
						"type": "string"
					"syslog_facility_code": {
						"type": "long"
					"syslog_hostname": {
						"type": "string"
					"syslog_message": {
						"type": "string"
					"syslog_pid": {
						"type": "string"
					"syslog_program": {
						"type": "string"
					"syslog_severity": {
						"type": "string"
					"syslog_severity_code": {
						"type": "long"
					"syslog_timestamp": {
						"type": "string"
I try adding adding the mapping by doing this in 7.6
PUT /syslog/_mapping
	"syslog": {
		"mappings": {
			"syslog": {
				"properties": {
					"@timestamp": {
						"type": "date",
					"@version": {
						"type": "string"
					"_index": {
						"type": "string"
					"_type": {
						"type": "string"
					"file": {
						"type": "string"
					"host": {
						"type": "string"
					"message": {
						"type": "string"
					"offset": {
						"type": "string"
					"received_at": {
						"type": "date",
					"received_from": {
						"type": "string"
						"type": "string"
						"type": "long"
						"type": "string"
					"syslog_message": {
						"type": "string"
					"syslog_pid": {
						"type": "string"
					"syslog_program": {
						"type": "string"
						"type": "string"
						"type": "long"
						"type": "string"
But I get the following error
  "error" : {
    "root_cause" : [
        "type" : "mapper_parsing_exception",
        "reason" : "Root mapping definition has unsupported parameters:  [syslog : {mappings={syslog={properties={syslog_pid={type=string}, syslog_severity_code={type=long}, _index={type=string}, offset={type=string}, syslog_facility={type=string}, _type={type=string}, syslog_facility_code={type=long}, syslog_program={type=string}, message={type=string}, syslog_message={type=string}, syslog_severity={type=string}, received_from={type=string}, @timestamp={format=dateOptionalTime, type=date}, file={type=string}, syslog_hostname={type=string}, received_at={format=dateOptionalTime, type=date}, syslog_timestamp={type=string}, @version={type=string}, host={type=string}}}}}]"
  "status" : 400
It does not tell me what the unsupported parameters are (and instead lists everything). Which parameters are not supported? How can I format it correctly so that is is accepted by the mapping API?
The JSON structure has been changed over the years, and you need to change yours in order to work with Elasticsearch 7 here.
I have tried to match what I found here https://www.elastic.co/guide/en/elasticsearch/reference/current/indices-put-mapping.html
but I still get the same error using this updated JSON
	"mappings": {
		"properties": {
			"@timestamp": {
				"type": "date",
			"@version": {
				"type": "string"
			"_index": {
				"type": "string"
			"_type": {
				"type": "string"
			"file": {
				"type": "string"
			"host": {
				"type": "string"
			"message": {
				"type": "string"
			"offset": {
				"type": "string"
			"received_at": {
				"type": "date",
			"received_from": {
				"type": "string"
				"type": "string"
				"type": "long"
				"type": "string"
			"syslog_message": {
				"type": "string"
			"syslog_pid": {
				"type": "string"
			"syslog_program": {
				"type": "string"
				"type": "string"
				"type": "long"
				"type": "string"
Because the error is unhelpful I am unable to solve this. I don't know if it is a bad property, bad JSON, or anything else. Please let me know what the error is with my mapping statement as I am unable to figure it out from the error elasticsearch gives and the docs.
According to the Put Mapping API docs a put-mapping request looks like this:
  "properties": {
Yours looks different:
  "mappings": {
    "properties": {
The error message says Root mapping definition has unsupported parameters: [mappings : {properties ... which tells you that the mappings key is indeed unexpected here.
Thank you! I am getting errors I can look up now, so progress is being made. I was mistakenly focused on this part of the docs since it was closest to the older formulation https://www.elastic.co/guide/en/elasticsearch/reference/current/indices-put-mapping.html#add-multi-fields-existing-field-ex
