How to design Drill Down chart and Dashboard using Kibana
Hello
how we can design drill down Charts using kibana ? Is there any plugin available for the same ? any kind of pointers would be appreciated
Thanks in Advance
Arun
Drilling down is as basic as having a visualisation and then filtering based on one of the values.
Hi Warkolm
thanks for the reply
Suppose there is a dashboard has a split chart which represents products with respect to the companies (lets say in X-axis we 've the companies list and in Y-axis we 've the products) If a user wants to see the information about a particular product and he click over it, then the dashboard should display another graph with information about that particular product alone How this can be achieve in kibana ?
Arun
If you click that product then the rest of the visualisations in the dashboard will only display data related to that product.
not sure this feature that I 've pointed is available in kibana
exact requirement is here
If you have a pie chart and a table, if you select a value from the pie chart then the table will only contain results related to whatever filter is applied.
But it won't take from you a pie chart into a filtered table.
thanks
