Hi All,
So my current elastic search setup is configured to receive records in monthly indexes.
Typically, to view a record of a specific condition, all I would need to do is to input some filter conditions through elasticsearch head extension plugin. However this method has some limitation as you can only get about 10,000 records.
So the problem comes when I want to pull out an index worth of data (in this case, a monthly index worth of approximately 100k records).
The question I would like to ask is there anyway to extract out all these raw data into a folder, and whether can it be a readable format like an excel sheet or word doc?
Regards
