How to fix Index Lifecycle Rollover Alias is empty or not defined
I've been running this (uses date math) but it doesn't seem to be working:
PUT /%3Cos-linux-%7Bnow%2Fd%7D-000001%3E
    "aliases": {
        "os-linux": {
            "is_write_index": true
which produces: os-linux-2024.01.23-000001
I deleted all old os-linux-* indices, stopped Logstash, ran the above command, then restarted Logstash but still same "illegal_argument_exception: setting [index.lifecycle.rollover_alias] for index [os-linux-2024.01.23] is empty or not defined"
Any advice?
Hi @roman-tasi
Share your output section of logstash
Also, what version are you on both elasticsearch and logstash?
@stephenb
Logstash output block:
        if [type]=="fortune" {
            hosts => ["localhost:9200"]
            index => "os-linux-%{+yyyy.MM.dd}"
        stdout { codec => rubydebug }
        if [type]=="syslog" {
                if [m] in [ "1080", "745", "263", "1079" ] {
                index => "account-access-%{+yyyy.MM}"
                } else {
                index => "syslog-%{+yyyy.MM.dd}"
        if [type]=="beats" {
                if [agent][type]=="auditbeat" {
                    index => "auditbeat-%{+yyyy.MM.dd}"
                if [agent][type]=="metricbeat" {
                    index => "metricbeat-%{+yyyy.MM.dd}"
                if [host][os][type]=="linux" {
                    #if [log][file][path]=="/var/log/audit/audit.log" {
                    #    path => "/etc/elasticsearch/audit-output.txt"
                    if [host][name]=="mail.uhtasi.org" {
                        if [cmd]=="Auth"{
                            } else {
                            index => "zimbra-%{+yyyy.MM.dd}"
                    } else {
                if [host][os][type]=="windows" or [agent][name]=="DCON2" or [agent][name]=="Dcon3" {
                    if [event][code] in [ "307", "4624", "4625", "4634", "4723", "4740", "4767", "11707" ] {
                    } else {
                        index => "winlogbeat-%{+yyyy.MM.dd}"
Both ES and Logstash are version 7.17.9
Do you have an index template that defines which ILM policy to apply?
If so, you are not writing to the write alias which you just show above
So your output index should be
index => "os-linux"
That is how it works you write to the write alias... Not the actual concrete index.
That is how rollover works
What is your index template look like??
Since it does not look like you're using data streams, you should be following these instructions
These are the settings of my os-linux index template:
  "index": {
    "lifecycle": {
      "name": "os-linux-policy"
    "number_of_shards": "1",
    "refresh_interval": "5s"
What I am confused about is that the other indices in my output block are following the index-%{+yyyy.MM.dd}" format without issue.
Hopefully I didn't accidentally close this topic.
I Can't tell you why the others because you haven't showed me all the information.
You haven't showed me enough of the template to show what indices it matches.
But I can tell you without a doubt. Absolutely certainty that when you create an alias for ILM purposes you need to write to the alias, not the concrete index if you want ILM to work
Did you carefully read the docs I linked
Do these match the index pattern in the template.
In short, those indices that you put the date on the end are daily indices. They are not managed by ILM
For example these are some of the settings on my zimbra-2024.01.19 :
"settings": {
    "index": {
      "lifecycle": {
        "name": "zimbra-policy"
      "routing": {
        "allocation": {
          "include": {
            "_tier_preference": "data_cold,data_warm,data_hot"
It is a daily index, however it seems to be automatically assigned to zimbra-policy. Any idea why?
Edit - Screenshot showing ILM :
Also want to mention it doesn't get the "Index Lifecycle Rollover Alias is empty or not defined" error.
Can you please show the entire index template except the mappings you are leaving out key parts.
Also.. perhaps we should step back and try to understand what you were trying to accomplish.
You are mixing concepts of daily indices with ILM and ILM with rollover. It's pretty common confusion.
What are you trying to do?
And I suggest we fix one thing at a time...
I don't have enough information parts of the information...
I would need to see the full
Template
Policy
And run some other commands to determine what is going on.
So what do you want to work on first? os- or Zimbra?
If you want to fix os- I will need to see
The entire ILM policy
The entire template except the mappings
@stephenb - I want to fix the os-linux first.
Here's the ILM policy:
PUT _ilm/policy/os-linux-policy
  "policy": {
    "phases": {
      "hot": {
        "min_age": "0ms",
        "actions": {
          "set_priority": {
            "priority": 100
          "rollover": {
            "max_age": "30d",
            "max_primary_shard_size": "50gb"
      "cold": {
        "min_age": "20h",
        "actions": {
          "set_priority": {
            "priority": 0
      "delete": {
        "min_age": "2d",
        "actions": {
          "delete": {
            "delete_searchable_snapshot": true
Here's the template w/o the mappings:
  "index": {
    "lifecycle": {
Thanks!
If that is in fact the complete index template you are missing a key part
"index_patterns": ["te*", "bar*"],
It looks like you are using legacy templates here
index_patterns
(Required, array of strings) Array of wildcard expressions used to match the names of indices during creation.
Without that the created index will not match the template and thus the ILM or anything else will not be applied. I an not sure how you even created a template without it
@stephenb - I am running this in Dev Tools (and yes it is a legacy template):
PUT _template/os-linux
  "index": {
    "lifecycle": {
But it is returning this:
  "error" : {
    "root_cause" : [
        "type" : "parse_exception",
        "reason" : "unknown key [index] in the template "
  "status" : 400
Any advice?
In create legacy template I just went through the required fields and got the template created (it didn't seem to ask for anything related to an array of wildcard expressions).
Bad syntax look at the examples further down the page..
Where you have index. Should be settings all the index settings go under that
"settings" : {
    "number_of_shards" : 1
settings
(Optional, index setting object) Configuration options for the index. See Index Settings.
In Dev Tools the helper should help with syntax
You can always use the new template as well
I'm trying this:
  "settings": {
    "number_of_shards": 1
  "lifecycle": {
but it is returning this:
  "error" : {
    "root_cause" : [
        "reason" : "unknown key [lifecycle] in the template "
  "status" : 400
Can you provide a command that works?
See if you can follow run these 1 at a time
  "index_patterns": [
    "os-linux-*"
  "settings": {
    "lifecycle": {
      "name": "os-linux-policy",
      "rollover_alias": "os-linux"
    "aliases": {
        "os-linux": {
POST os-linux/_doc
  "foo" : "bar"
# This will be whatever was created by the first command
GET os-linux-2024.01.25-000001
POST os-linux/_rollover
POST os-linux/_doc
  "foo" : "bar"
GET os-linux-*/_search
@stephenb - After running those commands, I am now getting this error for the newly created os-linux-2024.01.25 index:
illegal_argument_exception: index.lifecycle.rollover_alias [os-linux] does not point to index [os-linux-2024.01.25]
So at least it is a different error than the one posed in the original post of this thread.
Any advice on how to fix it?
Where and how are you getting that error?
Also those commands I provided were for you to learn the concepts / syntax no meant as ever commands.
Or
os-linux-2024.01.25
That particular error was coming from os-linux-2024.01.25 seen in Index Management. Currently it is gone but not sure if it will return when the policy changes phases or something like that.
