How to fix setting "indices.recovery.max_bytes_per_sec" in splitted cluster?
Hi guys!
I have a cluster (v5.6.4) with nodes in most default settings, and this settings works in cluster
9 nodes [all master eligible, ingest: (default=true), client: (default=true) and data: (default=true) ]
and with this config settings in all too:
cluster.routing.allocation.node_initial_primaries_recoveries: 2
cluster.routing.allocation.node_concurrent_recoveries: 2
indices.recovery.max_bytes_per_sec: 10mb
But, in my new cluster env (v5.6.16) with master, client, data and kibana in separated instances this configs are not to be applied.
I put the config in all nodes, but nothing...
What is wrong? Only dynamic?
Can you provide your cluster setting including the defaults? GET /_cluster/settings?include_defaults=true?
@rmsys The content was truncated. Can you make it as a gist?
bump
