How to increase max_clause_count in Elasticsearch 8.0.1 without using deprecated settings?
I recently upgraded Elasticsearch from version 7.5.1 to 8.0.1, and I encountered an issue with my queries that require around 20k boolean clauses. In Elasticsearch 7, I manually updated the persistent settings to increase the max_bool_clause_count value to allow for this. However, I noticed that in version 8.0.1, the max_clause_count setting has been deprecated.
I tried updating the max_clause_count, but it didn't reflect as its deprecated. Is there a recommended way to achieve the same result in Elasticsearch 8.0.1 without relying on deprecated settings? Can I configure this limit using any other method or is there an alternative approach to handling large boolean queries?
Here's the error that i am receiving:
  "took": 1817,
  "timed_out": false,
  "_shards": {
    "total": 380,
    "successful": 254,
    "skipped": 254,
    "failed": 126,
    "failures": [
        "shard": 0,
        "index": "some-index-1",
        "node": "sN_kzKnZQ2S_z7SG9CeYBQ",
        "reason": {
          "type": "too_many_nested_clauses",
          "reason": "too_many_nested_clauses: Query contains too many nested clauses; maxClauseCount is set to 1024"
        "shard": 8,
        "index": "some-index-2",
        "node": "dockY6h0Q0GO8oCNOB1LNA",
        "reason": {
          "type": "runtime_exception",
          "reason": "runtime_exception: [field.symbol:/00.{0,5}/ ] exceeds maxClauseCount [ Boolean maxClauseCount is set to 1024]"
  "hits": {
    "total": { "value": 0, "relation": "eq" },
    "max_score": 0.0,
    "hits": []
