How to insert document in index using SQL Query in elasticsearch
Hi All.
i have written SQL Query Like below:-
{"query":"select * from index02 where id=121"
Obove is working fine but i want to insert docs inside current index02:-1:
like:-
{"query":"insert into index02 values(122)"
How can i do like above?
You can't use Elasticsearch SQL to insert documents.
You need to use the Index Documents API instead or the bulk API.
Hi @dadoonet.
so we can say that...ES only allow to search query by using SQL Syntax?
We can't perform insert/update/delete by using sql syntax in elastic search index?.
That's the current status indeed.
Hi @dadoonet .
Thank you so much .
we hope that full sql support will come soon.
