How to map two Analyzers to a same field in an index?
I am indexing the documents from a SQL table and there are two fields 'parent_sentence' and 'parent_context' which are primarily used for search.
I am building synonym and 'search-as-you-type'/Partial search on both of those fields. While i am able to build analyzers for the said capabilities, I am unable to get desirable results.
My analyzers are such:
PUT diabetes/
  "settings": {
    "analysis": {
      "filter": {
        "synonym_filter" : {
          "type" : "synonym",
          "synonyms" : "synonyms.txt"
        "autocomplete_filter" : {
          "type": "edge_ngram",
          "min_gram": 4,
          "max_gram": 10
      "analyzer": {
        "synonym_analyzer" : {
        "tokenizer" : "standard",
        "filter" : ["lowercase","synonym_filter"]
        "autocomplete_analyzer" : {
And the corresponding mapping is as follows:
PUT diabetes/_mapping
  "properties": {
    "parent_context" : {
      "type" : "text",
      "analyzer": "autocomplete_analyzer",
      "fields": {
        "syn" : {
          "type" : "text",
          "analyzer" : "synonym_analyzer"
        "keyword" : {
          "type" : "keyword"
  "parent_sentence" : {
   "type" : "text",
   "fields": {
     "syn" : {
       "type" : "text",
      "keyword" : {
          "type" : "keyword"
When I query 'depre' (i am looking to get results containing word 'depression'), i get the following:
Query:
GET diabetes/_search
    "match": {
      "parent_context": {
        "query": "depre",
        "analyzer": "standard"
Result:
  "took" : 0,
  "timed_out" : false,
  "_shards" : {
    "total" : 1,
    "successful" : 1,
    "skipped" : 0,
    "failed" : 0
  "hits" : {
    "total" : {
      "value" : 0,
      "relation" : "eq"
    "max_score" : null,
    "hits" : [ ]
Hi @gauresh_chavan,
You have defined the filter autocomplete_filter but you are not using it in any analyzer.
I would suggest to change the autocomplete_analyzer analyzer to:
    "filter" : ["lowercase","autocomplete_filter"]
Best Regards
