I'm using Elasticsearch 7.10.0 and need to migrate data from index A to a new index B without interrupting write operations to index A. I want to achieve zero downtime during this migration and to migrate both the existing (historical) data and the new, incoming (incremental) data.
Here's my current situation:
Elasticsearch Version: 7.10.0
Source Index: A (actively receiving writes)
Destination Index: B (newly created, needs to be populated with data from A)
Constraint: I've found that using the Reindex API in my 7.10.0 setup can lead to significant performance degradation on index A or even data inconsistency issues. Therefore, I'm looking for alternative solutions that avoid or minimize the use of Reindex for bulk data transfer.
Requirement: Migrate both the full historical data from A and ensure that all new data written to A after the initial migration starts is also continuously synced to B.
Any advice, examples, or pointers to relevant documentation would be greatly appreciated. Thanks in advance for your help!
This is really old and have been EOL and without security updates for a long time. I recommend that you upgrade to the latest version of Elasticsearch.
Are you just adding new data or also performing updates and/or deletes?
I get it, this version is super old , but we’re stuck with it for now because of some external reasons. My data is just write-only though—no updates or deletes.
Any idea how I can fix this? Would really appreciate you help!
That makes it a lot easier. As you will need to reindex all the data there will be additional load and there is no way to avoid that. I would probebly try creating the new index and then redirecting new writes there. Once the old index is no longer written to you can start a reindexing job of this data to the new index. You will have duplicates for a period of time if both indices are included in queries, but this will go away once reindexing is done and the old index is deleted.
logo are trademarks of the
Apache Software Foundation
