How to plot speed derived from time and distance using aggregation
I have an query that calculates average speed for different car makes based on the fields 'distance' and 'time' in travel documents in Elasticsearch:
POST /test_data/_search
	"size": 0,
	"aggs": {
		"speed_per_make": {
			"terms": {
				"field": "CarMake"
			"aggs": {
				"sum_dist": {
					"sum": {
						"field": "DistanceCovered"
				"sum_time": {
					"sum": {
						"field": "DrivingDurationHours"
				"division": {
					"bucket_script": {
						"buckets_path": {
							"var_sum_dist": "sum_dist",
							"var_sum_time": "sum_time"
						"script": "params.var_dist / params.var_time"
For each car make it sums the distance and time, and then calculates the speed.
How can I plot this in a vertical bar chart?
Thanks!
Kibana core visualizations do not yet support bucket script aggregations, however you should be able to visualize this in TSVB if you are okay using a line chart instead of a bar chart.
Edit: adding a screengrab for clarity
Thanks for the quick reply!
I got it working by using vega. I can now display the average speed as a bar chart.
I will try TSVB too.
