How to prioritize exact match using nGram tokenizer? Solved, see solution
Hello All,
I am wondering, how to rank an exact match higher than the ngram matches.
For instance:
If I search for asus
It scores higher casual than asus or if I search for app it gives me first laptop and than it gives me apple
Settings
  "settings": {
    "index":{
      "max_ngram_diff": 20
    "analysis": {
      "analyzer": {
        "my_analyzer": {
          "type":"custom",
          "tokenizer": "my_tokenizer"
      "tokenizer": {
        "my_tokenizer": {
          "type": "ngram",
          "min_gram": 2 ,
          "max_gram": 20
Mapping
"properties" : {
  "analyzedName" : {
      "type" : "nested",
      "properties" : {
        "text" : {
          "type" : "text",
          "analyzer" : "my_analyzer"
Query
    "query":  {
        "nested" : {
            "path" : "analyzedName",
            "query" : {
                "bool" : {
                    "must" : [
                    { "match" : {"analyzedName.text" : "app"} }
Have a look at this gist. It demos it:
hello, can you exactly tell me which query you are talking about? There are many queries...
Sure: https://gist.github.com/dadoonet/5179ee72ecbf08f12f53d4bda1b76bab#file-search_kibana_console-txt-L362-L457
Query
GET index/_search
   "from":0,
   "query":{
      "bool":{
         "should":[
               "nested":{
                  "path":"analyzedName",
                  "query":{
                     "match":{
                        "analyzedName.text":{
                           "query":"top"
   "size":10
so, when i am searching for the word top , the first doc in hit is Laptop and second item is Top basic young ...
You can use multi-fields - map one field with ngrams and the other as whole-terms then search across both.
Scoring matching clauses is normally a the-more--the-merrier approach so this should work out.
This is what I am going to do...
Going to have settings like this:
PUT index
  "settings": {
    "index": {
      "max_ngram_diff": 50
    "analysis": {
      "filter": {
        "custom_shingle": {
          "max_shingle_size": "2",
          "min_shingle_size": "2",
          "output_unigrams": true,
          "type": "shingle"
        "my_char_filter": {
          "pattern": " ",
          "type": "pattern_replace",
          "replacement": ""
      "analyzer": {
        "nGram_analyzer": {
          "filter": [
            "lowercase"
          "tokenizer": "nGram_tokenizer"
        "bigram_analyzer": {
          "filter": [
            "lowercase",
            "custom_shingle",
            "my_char_filter"
          "tokenizer": "standard"
      "tokenizer": {
      "nGram_tokenizer": {
        "type": "ngram",
        "min_gram": 3,
        "max_gram": 20,
        "token_chars": [
          "letter",
          "digit"
and mapping
PUT index/_mapping
"properties" : {
      "analyzedName" : {
        "type" : "nested",
        "properties" : {
          "text" : {
            "type" : "text",
            "analyzer" : "bigram_analyzer"
      "ngramAnalyzedName" : {
        "type" : "nested",
        "properties" : {
          "text" : {
            "type" : "text",
            "analyzer" : "nGram_analyzer"
Search
on search i am going to boos AnalyzedName over NgramAnalyzedName field, what whould you say?
GET index/_search
    "bool": {
      "must": [
          "nested": {
            "path": "analyzedName",
              "match": {
                "analyzedName.text": {
                  "query": "iphone",
                  "boost": 3
          "nested": {
            "path": "ngramAnalyzedName",
              "match": {
                "ngramAnalyzedName.text": {
                  "query": "iphone",
                  "boost": 1
Anyone Looking for solution this worked for me
Is the nested type necessary here?
I Have multiple languages,so yes
PUT index
  "settings": {
    "index": {
    "analysis": {
      "filter": {
        "custom_shingle": {
          "type": "shingle"
        "my_char_filter": {
          "pattern": " ",
          "replacement": ""
      "analyzer": {
        "nGram_analyzer": {
          "filter": [
            "lowercase"
          "filter": [
            "lowercase",
            "custom_shingle",
            "my_char_filter"
      "tokenizer": {
        "type": "ngram",
        "min_gram": 3,
        "max_gram": 20,
        "token_chars": [
          "letter",
          "digit"
