I have shell script to get the status of the elk watcher
curl -k -s -X GET -H "Authorization: AAAAAA https://elastic
If the status is not started I am sending the alerts .
Now I also I want to start the elk watcher. (POST _watcher/_start) which works through dev tool in UI.
How to use this command (POST _watcher/_start) from curl throught the shell script to start watcher when the shell script is run.
Hey @basavarajvn0513,
You can get an example curl command via the docs here.
curl -X POST "<your elasticsearch>/_watcher/_start?pretty"
In get method I have authorization key and my elastic url
curl -k -s -X GET -H "Authorization: ApiKey AAAAAA "https://myelastic.com
In post method where to use authorization key and my elastic url.
Is my below command correct ?
curl -X POST "Authorization: ApiKey AAAAAA "https://myelastic.com/_watcher/_start?pretty"
