I have a es cluster with three data nodes. I create a data stream: myindex. when I write data into data stream using java client 8.5.3, I met a problem:
co.elastic.clients.elasticsearch._types.ElasticsearchException: [es/index] failed: [index_not_found_exception] no such index [myindex]
at co.elastic.clients.transport.rest_client.RestClientTransport.getHighLevelResponse(RestClientTransport.java:282)
at co.elastic.clients.transport.rest_client.RestClientTransport.performRequest(RestClientTransport.java:148)
at co.elastic.clients.elasticsearch.ElasticsearchClient.index(ElasticsearchClient.java:962)
This problem does not always occur, only occasionally.
my test code is:
import co.elastic.clients.elasticsearch.ElasticsearchClient;
import co.elastic.clients.elasticsearch._types.OpType;
import co.elastic.clients.elasticsearch.core.IndexRequest;
import co.elastic.clients.json.jackson.JacksonJsonpMapper;
import co.elastic.clients.transport.ElasticsearchTransport;
import co.elastic.clients.transport.rest_client.RestClientTransport;
import org.apache.http.HttpHost;
import org.elasticsearch.client.RestClient;
import org.junit.Test;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
public class ElasticSearchTest {
@Test
public void testDataStream() {
RestClient restClient = RestClient.builder(
new HttpHost("mydomain", 80)).build();
// Create the transport with a Jackson mapper
ElasticsearchTransport transport = new RestClientTransport(
restClient, new JacksonJsonpMapper());
// And create the API client
ElasticsearchClient esClient = new ElasticsearchClient(transport);
Map<String, String> document = new HashMap<>();
document.put("@timestamp", "2022-12-27 15:08:06.131");
document.put("rt", "123456");
try {
esClient.index(IndexRequest.of(item -> item.index("myindex").opType(OpType.Create).document(document)));
} catch (IOException e) {
throw new RuntimeException(e);
java client maven dep:
<dependency>
<groupId>co.elastic.clients</groupId>
<artifactId>elasticsearch-java</artifactId>
<version>8.5.3</version>
</dependency>
<dependency>
<groupId>org.apache.httpcomponents</groupId>
<artifactId>httpclient</artifactId>
<version>4.5.13</version>
</dependency>
<dependency>
<groupId>com.fasterxml.jackson.core</groupId>
<artifactId>jackson-databind</artifactId>
<version>2.12.3</version>
</dependency>
<dependency>
<groupId>jakarta.json</groupId>
<artifactId>jakarta.json-api</artifactId>
<version>2.0.1</version>
</dependency>
