iIhave problems Fleet daemonset collect kubernetes container logs
hello i have some problems operating elastic-agent with fleet
i did the settings elastic-agent usging kubernetes daemonset and kubernetes integration in fleet
and that setting works normally without problems
but suddenly resouce(cpu, memory)use increas and kebernetes work node problems due to resource load
when this time look FD for elastic-agent i find this 2000 count FD
lr-x------ 1 root root 64 Jun  5 10:18 220 -> /var/log/containers
lr-x------ 1 root root 64 Jun  3 07:57 221 -> /var/log/containers
lr-x------ 1 root root 64 Jun  3 07:57 222 -> /var/log/containers
lr-x------ 1 root root 64 Jun  3 07:57 223 -> /var/log/containers
lr-x------ 1 root root 64 Jun  5 09:11 224 -> /var/log/containers
lr-x------ 1 root root 64 Jun  5 09:11 225 -> /var/log/containers
lr-x------ 1 root root 64 Jun  3 12:52 226 -> /var/log/containers
lr-x------ 1 root root 64 Jun  5 10:17 227 -> /var/log/containers
lr-x------ 1 root root 64 Jun  3 12:52 228 -> /var/log/containers
lr-x------ 1 root root 64 Jun  4 07:56 229 -> /var/log/containers
and i can see Elastic-agent log as blow
elastic_agent.filebeat
[elastic_agent.filebeat][error] Error extracting container id - source value does not contain matcher's logs_path '/var/lib/docker/containers/'.
10:55:23.560
10:55:23.560
10:55:23.560
10:55:23.560
10:55:23.560
10:55:23.560
10:55:23.560
10:55:24.562
10:55:24.562
10:55:24.562
10:55:24.562
10:55:24.563
10:55:24.563
10:55:24.563
10:55:24.563
10:55:24.563
10:55:24.564
10:55:24.714
[elastic_agent.filebeat][info] Input 'filestream' stopped (goroutine)
10:55:24.714
[elastic_agent.filebeat][info] Reader was closed. Closing.
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
[elastic_agent.filebeat][info] Input 'filestream' stopped (runner)
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.714
10:55:24.737
[elastic_agent.filebeat][info] Input 'filestream' starting
10:55:24.752
10:55:24.780
10:55:24.802
10:55:24.818
10:55:24.877
[elastic_agent.filebeat][info] Applying settings for output
10:55:24.877
10:55:24.878
[elastic_agent.filebeat][info] elasticsearch url: https://hotnode01:9200
10:55:24.878
[elastic_agent.filebeat][info] Applying settings for filebeat.modules
10:55:25.364
elastic_agent
[elastic_agent][info] Source URI changed from "https://artifacts.elastic.co/downloads/" to "https://artifacts.elastic.co/downloads/"
10:55:25.475
elastic_agent
[elastic_agent][info] New State ID is k1Cbe68Z
10:55:25.475
elastic_agent
[elastic_agent][info] Converging state requires execution of 3 step(s)
10:55:25.563
[elastic_agent.filebeat][info] Connecting to backoff(elasticsearch(https://hotnode01:9200))
10:55:25.564
10:55:25.564
10:55:25.564
10:55:25.564
10:55:25.564
10:55:25.574
and
restart the elastic-agent pod and the problem will be normal.
may be 2 weeks and suddenly same problem occurs.
Please help me
