Running Elasticsearch 7.7.17. I have an issue moving the indexes to the warm node.
The indexes are on a healthy status (5 shards, 0 replicas) are in the right warm phase but I don't know why they don't move:
GET /network-000212/_ilm/explain
"indices" : {
"network-000212" : {
"index" : "network-000212",
"managed" : true,
"policy" : "network",
"lifecycle_date_millis" : 1598432918315,
"age" : "4.78d",
"phase" : "warm",
"phase_time_millis" : 1598530888787,
"action" : "allocate",
"action_time_millis" : 1598530888787,
"step" : "check-allocation",
"step_time_millis" : 1598530892134,
"step_info" : {
"message" : "Waiting for [5] shards to be allocated to nodes matching the given filters",
"shards_left_to_allocate" : 5,
"all_shards_active" : true,
"actual_replicas" : 0
"phase_execution" : {
"phase_definition" : {
"min_age" : "2d",
"actions" : {
"allocate" : {
"number_of_replicas" : 1,
"include" : { },
"exclude" : { },
"require" : {
"box_type" : "warm"
"version" : 6,
"modified_date_in_millis" : 1598610582875
GET /_cluster/allocation/explain { "index": "network-000212", "shard": 1, "primary": true }
"shard" : 1,
"primary" : true,
"current_state" : "started",
"current_node" : {
"id" : "z1AKYXOTQgSHJ1MNF7rh_A",
"name" : "authmattix",
"transport_address" : "1.2.3.4:9300",
"attributes" : {
"xpack.installed" : "true",
"box_type" : "hot",
"transform.node" : "true"
"can_remain_on_current_node" : "no",
"can_remain_decisions" : [
"decider" : "filter",
"decision" : "NO",
"explanation" : """node does not match index setting [index.routing.allocation.require] filters [box_type:"warm"]"""
"can_move_to_other_node" : "no",
"move_explanation" : "cannot move shard to another node, even though it is not allowed to remain on its current node"
So the error says it can't move it be cause of:
decision" : "NO", "explanation" : """node does not match index setting [index.routing.allocation.require] filters [box_type:"warm"]
But the warm node has the right attribute as shown from:
GET _cat/nodeattrs
elastic02 1.2.3.4 1.2.3.4 box_type warm
What am I missing here? Running out of ideas on how to troubleshoot this.
Thanks in advance for any feedback
