Index analyzer settings: is there a way to
Is there an index analyzer setting to:
  1. Treat diacritic letters (in my case polish diacritic letters ą, ć,
    ę, ł, ń, ó, ś, ź, ż) as US alphabet equivalents during search:
    ą -> a
    ć -> c
What I mean is when I do search with pattern 'abc' i want to see in
results 'abc' as well as 'ąbc', but when I search for 'ąbc' I want ES
to find only 'ąbc'
This settings do not work, I expected asciifolding might be doing the
trick:
index.analysis.analyzer.default.type: standard
index.analysis.analyzer.default.stopwords: none
index.analysis.analyzer.default.tokenizer: standard
index.analysis.analyzer.default.filter: [standard, lowercase, stop,
asciifolding, porter_stem]
ES 18.7
Cheers!
Michal
Are you sure you are using a query that also analyzes the search text? (query_string, field, text)? If so, can you gist a recreation (Elasticsearch Platform — Find real-time answers at scale | Elastic)?
    ą -> a
    ć -> c
to find only 'ąbc'
trick:
ES 18.7
Cheers!
Michal
