Thanks David.
On 6 March 2014 16:56, David Pilato david@pilato.fr wrote:
wildcard queries are not analyzed.
may be d* will work in your case.--
David Pilato | Technical Advocate | Elasticsearch.com
@dadoonet https://twitter.com/dadoonet | @elasticsearchfrhttps://twitter.com/elasticsearchfrLe 6 mars 2014 à 11:50:46, Nitesh Earkara (enitesh@gmail.com) a écrit:
Hi David,
Thanks a lot for your help through out.
I have raised issue for the same.
Url - file.filename should be not_analyzed · Issue #53 · dadoonet/fscrawler · GitHub
Please let me know once fix is available
Also I am not able to do a wildcard search
POST /mydocs/doc/_search
{"query": {"wildcard": {"content": "D*"}}}Above query returns no result eventhough there's a text Dear in the file
contents
AlsoOn 6 March 2014 14:43, David Pilato david@pilato.fr wrote:
Ha! I see.
curl "localhost:9200/_analyze?analyzer=simple&pretty" -d
'AnnualCompensation_20122013.pdf'{
"tokens" : [ {
"token" : "annualcompensation", "start_offset" : 0, "end_offset" : 18, "type" : "word", "position" : 1}, {
"token" : "pdf", "start_offset" : 28, "end_offset" : 31, "type" : "word", "position" : 2} ]
Simple Analyzer does not simply lowercase the content but also break
tokens which is not what I was expecting when reading:
Elasticsearch Platform — Find real-time answers at scale | Elastic
I should have read all details (one click later):
A tokenizer of type lowercase that performs the function of Letter
Tokenizerhttp://www.elasticsearch.org/guide/en/elasticsearch/reference/current/analysis-letter-tokenizer.html
and Lower Case Token Filterhttp://www.elasticsearch.org/guide/en/elasticsearch/reference/current/analysis-lowercase-tokenfilter.html together.
It divides text at non-letters and converts them to lower case. While it is
functionally equivalent to the combination of Letter Tokenizerhttp://www.elasticsearch.org/guide/en/elasticsearch/reference/current/analysis-letter-tokenizer.html
and Lower Case Token Filterhttp://www.elasticsearch.org/guide/en/elasticsearch/reference/current/analysis-lowercase-tokenfilter.html,
there is a performance advantage to doing the two tasks at once, hence this
(redundant) implementation.Could you open an issue in FSRiver project so I can fix that?
--David Pilato | Technical Advocate | Elasticsearch.com
@dadoonet https://twitter.com/dadoonet | @elasticsearchfrhttps://twitter.com/elasticsearchfrLe 6 mars 2014 à 09:55:12, Nitesh Earkara (enitesh@gmail.com) a écrit:
Even the lowercase didn't work.
On 6 March 2014 14:23, David Pilato david@pilato.fr wrote:
Probably because you need to lowercase it in that case:
GET /mydocs/doc/_search
"query" : {
"term" : {
"file.filename" : "annualcompensation_20132014.pdf"
}--David Pilato | Technical Advocate | Elasticsearch.com
@dadoonet https://twitter.com/dadoonet | @elasticsearchfrhttps://twitter.com/elasticsearchfrLe 6 mars 2014 à 09:51:13, Nitesh Earkara (enitesh@gmail.com) a écrit:
Thanks David.
GET /mydocs/doc/_mapping?pretty
This query returns below result
"doc": {
"properties": {
"content": {
"type": "string",
"store": true
"file": {
"properties": {
"content_type": {
"type": "string",
"store": true,
"analyzer": "simple"
"filename": {
"type": "string",
"store": true,
"analyzer": "simple"I am not pasting complete result.
If i use term query, then i don't get any result
"query" : {
"term" : {
"file.filename" : "AnnualCompensation_20132014.pdf"
}Result is
- "took": 2,*
- "timed_out": false,*
- "_shards": {*
"total": 5,*"successful": 5,*"failed": 0*- },*
- "hits": {*
"total": 0,*"max_score": null,*"hits": []*- }*
}On 6 March 2014 13:55, David Pilato david@pilato.fr wrote:
Hmm...
I looked at the code of fsriver 0.4.0 and it sounds like I use by
default simple analyzer on file.filename field.So your query should work...
Just to check, could you try with a TermQuery instead a MatchQuery?
Could you also gist the mapping?
@dadoonet https://twitter.com/dadoonet | @elasticsearchfrhttps://twitter.com/elasticsearchfrLe 6 mars 2014 à 09:17:20, Nitesh Earkara (enitesh@gmail.com) a écrit:
Thanks David.
Can you suggest which query should I use for exact match?
Thanks & Regards,
Nithesh Erakkara
Phone :- +91-9833-742-684
Email :- enitesh@gmail.com
On 6 Mar 2014, at 13:10, David Pilato david@pilato.fr wrote:
Probably because file.filename is analyzed.
Using a match query will basically search here for "mydocument" or
"pdf".Default mapping and field names will change with coming FSriver 1.0.
David
Twitter : @dadoonet / @elasticsearchfr / @scrutmydocsLe 6 mars 2014 à 08:25, Nitesh Earkara enitesh@gmail.com a écrit :
Hi David,
I did install 0.90.12 version of es and installed plugin fsriver 0.4.0.
Now the query
GET /mydocs/_search
is retrieving me results of all the document present in the folder as
per indexbut when I run query
"query" : {
"match" : {
"file.filename" : "mydocument.pdf"
}it retrieves all results and not just the document that has file name
mydocument.pdf.Please let me know if I am querying properly or do let me know the
proper syntax for the same.On 6 March 2014 12:12, Nitesh Earkara enitesh@gmail.com wrote:
Hi David,
Thanks. So is there a bug in existing fsriver or is it not compatible
with es 1.0.If its compatible with any previous version of es, let me know. I
would like to try it out.Also if there are any other rivers i can use , do let me know.
On 6 March 2014 12:08, David Pilato david@pilato.fr wrote:
Fsriver has not been released yet for es 1.0.
I will do it soonish.
David
Twitter : @dadoonet / @elasticsearchfr / @scrutmydocsLe 6 mars 2014 à 06:31, Nitesh Earkara enitesh@gmail.com a écrit :
My Elasticsearch server window shows below things displayed
[2014-03-05 17:21:22,782][INFO ][node ] [Frank
Payne] versio
n[1.0.1], pid[4896], build[5c03844/2014-02-25T15:52:53Z]
[2014-03-05 17:21:22,784][INFO ][node ] [Frank
Payne] initia
lizing ...
[2014-03-05 17:21:23,697][INFO ][plugins ] [Frank
Payne] loaded
[jdbc-river, river-fs], sites
[2014-03-05 17:21:31,848][INFO ][node ] [Frank
Payne] initia
lized
Payne] starti
ng ...
[2014-03-05 17:21:32,308][INFO ][transport ] [Frank
Payne] bound_
address {inet[/0:0:0:0:0:0:0:0:9301]}, publish_address {inet[/
192.9.205.37:9301]
[2014-03-05 17:21:35,669][INFO ][cluster.service ] [Frank
Payne] detect
ed_master [Mad Thinker][5SmeADN9SYex_owrQ9CLHA][JLTIVMDEV10][inet[/
192.9.205.37:
9300]], added {[Mad
Thinker][5SmeADN9SYex_owrQ9CLHA][JLTIVMDEV10][inet[/192.9.20
5.37:9300]],}, reason: zen-disco-receive(from master [[Mad
owrQ9CLHA][JLTIVMDEV10][inet[/192.9.205.37:9300]]])
[2014-03-05 17:21:35,725][INFO ][discovery ] [Frank
Payne] elasti
csearch/A8mG-X4_S3KPLnQj9gPLfg
[2014-03-05 17:21:35,822][INFO ][http ] [Frank
Payne] bound
address {inet[/0:0:0:0:0:0:0:0:9201]}, publish_address {inet[/
192.9.205.37:9201]
[2014-03-05 17:21:35,826][INFO ][node ] [Frank
Payne] starte
d
[2014-03-05 17:22:07,045][INFO
][fr.pilato.elasticsearch.river.fs.river.FsRiver]
[Frank Payne] [fs][mynewriver] Starting fs river scanning
[2014-03-05 17:22:07,062][WARN ][river ] [Frank
Payne] failed
to get _meta from [fs]/[mynewriver]
java.lang.NoSuchMethodError:
org.elasticsearch.action.admin.cluster.state.Cluste
rStateRequestBuilder.setFilterIndices([Ljava/lang/String;)Lorg/elasticsearch/act
ion/admin/cluster/state/ClusterStateRequestBuilder;
at
fr.pilato.elasticsearch.river.fs.river.FsRiver.isMappingExist(FsRiver
.java:300)
at
fr.pilato.elasticsearch.river.fs.river.FsRiver.pushMapping(FsRiver.ja
va:315)
at
fr.pilato.elasticsearch.river.fs.river.FsRiver.start(FsRiver.java:229
at
org.elasticsearch.river.RiversService.createRiver(RiversService.java:
148)
at
org.elasticsearch.river.RiversService$ApplyRivers$2.onResponse(Rivers
Service.java:275)
at
Service.java:269)
at
org.elasticsearch.action.support.TransportAction$ThreadedActionListen
er$1.run(TransportAction.java:93)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown
Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown
Source)
at java.lang.Thread.run(Unknown Source)On 6 March 2014 10:32, Nitesh Earkara enitesh@gmail.com wrote:
And if I run query
GET /_river/mydocs/_meta
I get result
"_index": "_river",
"_type": "mydocs",
"_id": "_meta",
"found": false
}On 6 March 2014 10:29, Nitesh Earkara enitesh@gmail.com wrote:
Hi David,
I am using version 0.4.0
On 5 March 2014 23:10, David Pilato david@pilato.fr wrote:
Are U using an old version of fsriver?
http://Elasticsearch.com
@dadoonet https://twitter.com/dadoonet | @elasticsearchfrhttps://twitter.com/elasticsearchfrLe 5 mars 2014 à 17:58:54, Nitesh Earkara (enitesh@gmail.com) a
écrit:Even that gave me same results
Thanks & Regards,
Nithesh Erakkara
On 5 Mar 2014, at 22:20, David Pilato david@pilato.fr wrote:
Don't search in _river index but in destination index, which is
mydocsin your case.--David Pilato | Technical Advocate | Elasticsearch.com
@dadoonet https://twitter.com/dadoonet | @elasticsearchfrhttps://twitter.com/elasticsearchfrLe 5 mars 2014 à 11:50:47, Nitesh Earkara (enitesh@gmail.com) a
écrit:Hi,
I am trying to index files in my system using fsriver and then
search them. But I'm not able to search them.Below is the steps performed.
- Create a local fs river
PUT /_river/mynewriver/_meta
"type": "fs",
"fs": {
"url": "C:\Users\ner\Downloads\TCS Docs\Compenstion
Letters\",
"update_rate": 3600000,
"includes": [ ".doc" , ".xls", "*.pdf" ]
"index": {
"index": "mydocs",
"type": "doc",
"bulk_size": 50
- Check if river created or not
GET /_river/mynewriver/_search
- Search file
POST /_river/mynewriver/_search
"query" : {
"term" : {
"file.filename" : "AnniversayLetter_20112012.pdf"
}The last query for search retrieves result
"took": 1,
"timed_out": false,
"_shards": {
"total": 1,
"successful": 1,
"failed": 0
"hits": {
"total": 0,
"max_score": null,
"hits":
}It doesn't return the file details although file is present in
folderAnyone has any idea????
You received this message because you are subscribed to the Google
Groups "elasticsearch" group.
To unsubscribe from this group and stop receiving emails from it,
send an email to elasticsearch+unsubscribe@googlegroups.com.
To view this discussion on the web visit
https://groups.google.com/d/msgid/elasticsearch/a78b4d1e-9809-4869-8bf6-bf1e068a01e8%40googlegroups.comhttps://groups.google.com/d/msgid/elasticsearch/a78b4d1e-9809-4869-8bf6-bf1e068a01e8%40googlegroups.com?utm_medium=email&utm_source=footer
For more options, visit https://groups.google.com/groups/opt_out.--
You received this message because you are subscribed to a topic in
the Google Groups "elasticsearch" group.
To unsubscribe from this topic, visit
https://groups.google.com/d/topic/elasticsearch/DPS3JNvXQDA/unsubscribe
To unsubscribe from this group and all its topics, send an email
https://groups.google.com/d/msgid/elasticsearch/etPan.531755c3.1f16e9e8.7bfa%40MacBook-Air-de-David.localhttps://groups.google.com/d/msgid/elasticsearch/etPan.531755c3.1f16e9e8.7bfa%40MacBook-Air-de-David.local?utm_medium=email&utm_source=footer
https://groups.google.com/d/msgid/elasticsearch/0DF7F966-1057-4E8C-846F-D6023D32FD50%40gmail.comhttps://groups.google.com/d/msgid/elasticsearch/0DF7F966-1057-4E8C-846F-D6023D32FD50%40gmail.com?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
https://groups.google.com/d/msgid/elasticsearch/etPan.5317618c.ded7263.7bfa%40MacBook-Air-de-David.localhttps://groups.google.com/d/msgid/elasticsearch/etPan.5317618c.ded7263.7bfa%40MacBook-Air-de-David.local?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
+919833742684--
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
+919833742684--
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
+919833742684You received this message because you are subscribed to the Google
https://groups.google.com/d/msgid/elasticsearch/CAOkk-nb8-mF0G6O_SzUstuEyXCkXGFtBLJ%2BO49LnzE8gjesw5w%40mail.gmail.comhttps://groups.google.com/d/msgid/elasticsearch/CAOkk-nb8-mF0G6O_SzUstuEyXCkXGFtBLJ%2BO49LnzE8gjesw5w%40mail.gmail.com?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
To unsubscribe from this group and all its topics, send an email to
https://groups.google.com/d/msgid/elasticsearch/1E4E8DAC-9184-4484-9B33-6C735592B5EA%40pilato.frhttps://groups.google.com/d/msgid/elasticsearch/1E4E8DAC-9184-4484-9B33-6C735592B5EA%40pilato.fr?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
+919833742684--
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
To unsubscribe from this group and stop receiving emails from it, send
https://groups.google.com/d/msgid/elasticsearch/CAOkk-nY-abDqFRgc4bOoCR0x1xnvSR76mBmHn5v19e94fMxtXw%40mail.gmail.comhttps://groups.google.com/d/msgid/elasticsearch/CAOkk-nY-abDqFRgc4bOoCR0x1xnvSR76mBmHn5v19e94fMxtXw%40mail.gmail.com?utm_medium=email&utm_source=footer
For more options, visit https://groups.google.com/groups/opt_out.You received this message because you are subscribed to a topic in the
https://groups.google.com/d/msgid/elasticsearch/B5E9B8E3-D55A-4348-9CF5-8C24E1A29DC6%40pilato.frhttps://groups.google.com/d/msgid/elasticsearch/B5E9B8E3-D55A-4348-9CF5-8C24E1A29DC6%40pilato.fr?utm_medium=email&utm_source=footer
https://groups.google.com/d/msgid/elasticsearch/6140EC4B-2E75-4FC4-8E10-C4BED6ADFB11%40gmail.comhttps://groups.google.com/d/msgid/elasticsearch/6140EC4B-2E75-4FC4-8E10-C4BED6ADFB11%40gmail.com?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
https://groups.google.com/d/msgid/elasticsearch/etPan.531830fe.333ab105.7bfa%40MacBook-Air-de-David.localhttps://groups.google.com/d/msgid/elasticsearch/etPan.531830fe.333ab105.7bfa%40MacBook-Air-de-David.local?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
https://groups.google.com/d/msgid/elasticsearch/CAOkk-naqpjY5rm4Doq-31hnLg03EhTahtOb_UgkhnWVqLkvKGw%40mail.gmail.comhttps://groups.google.com/d/msgid/elasticsearch/CAOkk-naqpjY5rm4Doq-31hnLg03EhTahtOb_UgkhnWVqLkvKGw%40mail.gmail.com?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
https://groups.google.com/d/topic/elasticsearch/DPS3JNvXQDA/unsubscribe.
https://groups.google.com/d/msgid/elasticsearch/etPan.53183787.1e7ff521.7bfa%40MacBook-Air-de-David.localhttps://groups.google.com/d/msgid/elasticsearch/etPan.53183787.1e7ff521.7bfa%40MacBook-Air-de-David.local?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
+919833742684You received this message because you are subscribed to the Google Groups
https://groups.google.com/d/msgid/elasticsearch/CAOkk-nayyA%3DNsvnxumoUg6wHMqWdDTaQ-eKBxq4Gv9uQE%2B5pTw%40mail.gmail.comhttps://groups.google.com/d/msgid/elasticsearch/CAOkk-nayyA%3DNsvnxumoUg6wHMqWdDTaQ-eKBxq4Gv9uQE%2B5pTw%40mail.gmail.com?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
https://groups.google.com/d/msgid/elasticsearch/etPan.53183c3a.5c482a97.7bfa%40MacBook-Air-de-David.localhttps://groups.google.com/d/msgid/elasticsearch/etPan.53183c3a.5c482a97.7bfa%40MacBook-Air-de-David.local?utm_medium=email&utm_source=footer.For more options, visit https://groups.google.com/groups/opt_out.
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
https://groups.google.com/d/msgid/elasticsearch/CAOkk-napc%3Dj7fTSJL9a_tCM14uqMamEuqVUeFr3ELxjVxORBdA%40mail.gmail.comhttps://groups.google.com/d/msgid/elasticsearch/CAOkk-napc%3Dj7fTSJL9a_tCM14uqMamEuqVUeFr3ELxjVxORBdA%40mail.gmail.com?utm_medium=email&utm_source=footer
https://groups.google.com/d/msgid/elasticsearch/etPan.53185b61.180115be.7bfa%40MacBook-Air-de-David.localhttps://groups.google.com/d/msgid/elasticsearch/etPan.53185b61.180115be.7bfa%40MacBook-Air-de-David.local?utm_medium=email&utm_source=footer
Thanks & Regards,
Nithesh Erakkara
enitesh@gmail.com
+919833742684
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAOkk-nZmr3JrJ18a_V2APeA38uy42e1L174hoYhtdoNTNSLsuA%40mail.gmail.com.
