Index lifecycle policy not applied to active index
I have created a new ELK 7.0 stack and am struggling with index roll over.
Currently I have a packetbeat-7.0.0-2019.04.21-000001 index that is 55gb large, the alias of that index is packetbeat-7.0.0.
The attached lifecycle policy is more or less the basis policy, 50gigabytes but max age of 6 hours
Below is the json output of the policy
    "policy": {
        "phases": {
            "hot": {
                "min_age": "0ms",
                "actions": {
                    "rollover": {
                        "max_age": "6h",
                        "max_size": "50gb"
When I check the phase definition on the index it gives the following output
  "policy": "packetbeat-7.0.0",
  "phase_definition": {
    "min_age": "0ms",
    "actions": {
      "rollover": {
        "max_size": "50gb",
        "max_age": "30d"
  "version": 1,
  "modified_date_in_millis": 1555844316520
GET packetbeat-7.0.0-2019.04.21-000001/_ilm/explain gives the following output
  "indices" : {
    "packetbeat-7.0.0-2019.04.21-000001" : {
      "index" : "packetbeat-7.0.0-2019.04.21-000001",
      "managed" : true,
      "policy" : "packetbeat-7.0.0",
      "lifecycle_date_millis" : 1555844317187,
      "phase" : "hot",
      "phase_time_millis" : 1555844317507,
      "action" : "rollover",
      "action_time_millis" : 1555844530404,
      "step" : "check-rollover-ready",
      "step_time_millis" : 1555844530404,
      "phase_execution" : {
        "phase_definition" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_size" : "50gb",
              "max_age" : "30d"
        "version" : 1,
        "modified_date_in_millis" : 1555844316520
I was expecting a rollover based on the data size of 50gb but nothing happened.
What should I change or do to start the automatic roll over to a new index after eq. 6 hours?
thnxz
John
Hmmm, can it be that the size being shown is 55gb while the primaries is "only" 28gb and not near the 50gb limit defined in the policy?
GET packetbeat-7.0.0-2019.04.21-000001/_stats
  "_shards" : {
    "total" : 2,
    "successful" : 2,
    "failed" : 0
  "_all" : {
    "primaries" : {
      "docs" : {
        "count" : 81593179,
        "deleted" : 0
      "store" : {
        "size_in_bytes" : 30066485090
      "indexing" : {
        "index_total" : 72882006,
        "index_time_in_millis" : 53494651,
        "index_current" : 0,
        "index_failed" : 0,
        "delete_total" : 0,
        "delete_time_in_millis" : 0,
        "delete_current" : 0,
        "noop_update_total" : 0,
        "is_throttled" : false,
        "throttle_time_in_millis" : 0
Fixed it.
I removed the lifecycle policy from the index and added it again.
Now it is working as expected
