"index" : "packetbeat-7.3.0-000001",
"shard" : 0,
"primary" : false,
"current_state" : "unassigned",
"unassigned_info" : {
"reason" : "CLUSTER_RECOVERED",
"at" : "2019-11-06T20:31:04.071Z",
"last_allocation_status" : "no_attempt"
"can_allocate" : "no",
"allocate_explanation" : "cannot allocate because allocation is not permitted to any of the nodes",
"node_allocation_decisions" : [
"node_id" : "0j54YASqTNOnOKXpr4Nz5A",
"node_name" : "INDY-LOGSRV01",
"transport_address" : "10.3.200.45:9300",
"node_attributes" : {
"ml.machine_memory" : "68718940160",
"xpack.installed" : "true",
"box_type" : "hot",
"ml.max_open_jobs" : "20"
"node_decision" : "no",
"deciders" : [
"decider" : "max_retry",
"decision" : "YES",
"explanation" : "shard has no previous failures"
"decider" : "replica_after_primary_active",
"decision" : "YES",
"explanation" : "primary shard for this replica is already active"
"decider" : "enable",
"decision" : "YES",
"explanation" : "all allocations are allowed"
"decider" : "node_version",
"decision" : "YES",
"explanation" : "can allocate replica shard to a node with version [7.3.0] since this is equal-or-newer than the primary version [7.3.0]"
"decider" : "snapshot_in_progress",
"decision" : "YES",
"explanation" : "the shard is not being snapshotted"
"decider" : "restore_in_progress",
"decision" : "YES",
"explanation" : "ignored as shard is not being recovered from a snapshot"
"decider" : "filter",
"decision" : "NO",
"explanation" : """node does not match index setting [index.routing.allocation.require] filters [box_type:"warm"]"""
"decider" : "same_shard",
"decision" : "YES",
"explanation" : "the shard does not exist on the same node"
"decider" : "disk_threshold",
"decision" : "YES",
"explanation" : "enough disk for shard on node, free: [283.8gb], shard size: [0b], free after allocating shard: [283.8gb]"
"decider" : "throttling",
"decision" : "YES",
"explanation" : "below shard recovery limit of outgoing: [0 < 2] incoming: [0 < 2]"
"decider" : "shards_limit",
"decision" : "YES",
"explanation" : "total shard limits are disabled: [index: -1, cluster: -1] <= 0"
"decider" : "awareness",
"decision" : "YES",
"explanation" : "allocation awareness is not enabled, set cluster setting [cluster.routing.allocation.awareness.attributes] to enable it"
> "node_id" : "GqP1krHiTX6Iqe0t9bzvaQ",
> "node_name" : "INDY-LOGSRV06",
> "transport_address" : "10.3.200.50:9300",
> "ml.max_open_jobs" : "20",
> "box_type" : "hot"
> "deciders" : [
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "NO",
> "decision" : "YES",
> "decision" : "YES",
> "explanation" : "enough disk for shard on node, free: [317.7gb], shard size: [0b], free after allocating shard: [317.7gb]"
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "node_id" : "Xzmh5yzfRhOPwRK0gBiujw",
> "node_name" : "INDY-LOGSRV02",
> "transport_address" : "10.3.200.46:9300",
> "box_type" : "warm"
> "deciders" : [
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "explanation" : "node passes include/exclude/require filters"
> "decision" : "NO",
> "explanation" : "the shard cannot be allocated to the same node on which a copy of the shard already exists [[packetbeat-7.3.0-000001][0], node[Xzmh5yzfRhOPwRK0gBiujw], [P], s[STARTED], a[id=DnG9RX2FSTmurLu91iTK5Q]]"
> "decision" : "YES",
> "explanation" : "enough disk for shard on node, free: [231.4gb], shard size: [0b], free after allocating shard: [231.4gb]"
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "node_id" : "oIyIKckYTAia9O8L8DYFRw",
> "node_name" : "INDY-LOGSRV05",
> "transport_address" : "10.3.200.49:9300",
> "ml.machine_memory" : "25756258304",
> "box_type" : "cold"
> "deciders" : [
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "NO",
> "decision" : "YES",
> "decision" : "YES",
> "explanation" : "enough disk for shard on node, free: [4.3tb], shard size: [0b], free after allocating shard: [4.3tb]"
> "decision" : "YES",
> "decision" : "YES",
> "decision" : "YES",
Sorry for the 3 posts. I didn't want to leave out something important again.
Thank you
I'm only seeing one "warm" node, which is where the primary is. Do you have at least 2 warm nodes?
What does
GET _cat/nodeattrs?h=name,attr,value
return?
And what is the size of the index?
The command gets the following:
INDY-LOGSRV02 ml.machine_memory 68718940160
INDY-LOGSRV02 ml.max_open_jobs 20
INDY-LOGSRV02 xpack.installed true
INDY-LOGSRV02 box_type warm
INDY-LOGSRV06 ml.machine_memory 68718940160
INDY-LOGSRV06 ml.max_open_jobs 20
INDY-LOGSRV06 xpack.installed true
INDY-LOGSRV06 box_type hot
INDY-LOGSRV01 ml.machine_memory 68718940160
INDY-LOGSRV01 xpack.installed true
INDY-LOGSRV01 box_type hot
INDY-LOGSRV01 ml.max_open_jobs 20
INDY-LOGSRV05 ml.machine_memory 25756258304
INDY-LOGSRV05 ml.max_open_jobs 20
INDY-LOGSRV05 xpack.installed true
INDY-LOGSRV05 box_type cold
I only have 1 Warm node. I was shrinking the shards down to 1 on the move to the warm node.
The index size is just under 53Gbs.
Could the problem be that the index was created before I assigned the Hot, Warm, Cold settings?
Ok. That means reducing to a single primary shard from however many primary shards the index has in its hot stage. That does not mean no replicas, so if you have the index configured for a single replica per shard, you'll have one primary and one replica.
If you want no replicas, you need to set number_of_replics to 0 in your ILM allocation action.
In the meantime, you can drop the replica(s) on any offending index directly.
PUT /packetbeat-7.3.0-000001/_settings
"index" : {
"number_of_replicas" : 0
To make sure I understand correctly. On the Warm Phase of ILM I set the replicas to 0 then that should solve my issue. I will need to run the the command from of above on all my indexes that have rolled over. I will have to do the same when it rolls over again, but after the roll over it will be automatic. The ILM index change won't take effect until index 003.
Thank you
Yes, that sounds correct.
If you only have 2 unallocated shards, though, it sounds like you have maximum 2 warm indices to manually fix.
Just to belabor the obvious, this means you will not have any replicas on your warm indices. If you lose your single warm node, you will lose all those indices.
You should consider systematic snapshotting of indices, if you are not already doing so. As yet, this isn't a capability of ILM, so an external agent must be used. Curator is a tool for exactly such purposed.
I have did what you have suggested. Nothing is being written to the new indexes. Will this take sometime or rather quickly?
Thank you for all your help and helping me understand.
I don't understand. What are the "new indices"? From the daily rollover, or something else?
Is your cluster now green (i.e. no more unallocated shards)?
That appears to be a completely distinct issue to the shard allocation issue.
Is your cluster now green, all shards allocated?
If so, I'd recommend opening a new topic.
Yes my cluster is Green.
Thank you for your help.
