"index":"no" does not work
I'm using dynamic mapping for indexing. Above you can see PHP
structure of data.
array("mailing_index" =>
array("properties" =>
array(
"f_id" =>
array("type" => "long"),
"f_from" =>
array("type" => "string",
"index" => "analyzed", "analyzer" => "default"),
"f_subject" =>
"index" => "not_analyzed"),
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
array("type" => "integer",
"index" => "no"),
"f_datetime" =>
array("type" => "long",
"f_userid" =>
As you can see "f_reply_to" field marked as "index" => "no". But I am
able to perform search by this field. In documentation of elastic
search we can find a line " "index:no" means that it won’t be
searchable at all". Used the 0.17.6 version of elasticsearch. Same
behavior for 0.17.0.
Maybe I'm doing something wrong, please help me to understand the
situation.
//////////////////////// config file
content //////////////////////////////////
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
tokenizer : standard
filter : [standard, lowercase, porterStem, stop]
network.publish_host: 127.0.0.1
network.bind_host: 127.0.0.1
network.host: 127.0.0.1
node.data: true # Default
http.port: 9200 # Default
cluster.name: "TestCluster"
//////////////////////// end of config file
Thanks in advance
H. Avetsyan
Two things: How do you search for the value? Do you search against the
specific field? By default, it is added to the _all field (and its the
default field being searched on). You can disable it from being added to the
_all field as well. Also, make sure the mapping you set is actually the
mapping you identified by elasticsearch, use the get mapping API to check it
out.
On Wed, Aug 17, 2011 at 12:47 PM, hamazasp.avetisyan <
hamazasp.avetisyan@gmail.com> wrote:
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
Hi, thank you for reply!
For mapping I am using the following URL
host:port/my_db/mailing_index/_mapping
As you can see no "_all" specified
For searching I am using the following URL
host:port/TestCluster/mailing_index/_search
The argument for sort operation contains just a Boolean condition(with
query string), limits and sorting. No "_all" specified.
I've checked the structure of index using get mapping API, everything
is OK (as I specified in argument for mapping).
So the issue still exists.
Best regards,
H.Avetisyan
out.
hamazasp.avetis...@gmail.com> wrote:
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
host:port/my_db/mailing_index/_search
condition(with
Best regards,
H.Avetisyan
out.
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
The argument for search contains a Boolean condition(with
Best regards,
H.Avetisyan
out.
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
As you can see no "_all" specified.
The argument for search operation contains a Boolean condition(with
Best regards,
H.Avetisyan
out.
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
What I meant is what type of query do you execute when you say it does not
work?
On Thu, Aug 18, 2011 at 11:20 AM, hamazasp.avetisyan <
Best regards,
H.Avetisyan
the
it
out.
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
to the _all field as well. Also, make sure the mapping you set is
actually the mapping you identified by elasticsearch, use the get
mapping API to check it out.
Note: there is an issue open to disable include_in_all when index: "no"
is specified, as it is more Do-What-I-Mean
clint
hamazasp.avetisyan@gmail.com wrote:
structure of data.
                                       array(
                                       "f_id" =>
                                           array("type" =>
    "long"),
                                       "f_from" =>
                                           array("type" =>
    "string",
                                       "f_subject" =>
                                           array("type" =>
    "string",
                                       "f_body" =>
                                           array("type" =>
    "string",
                                       "f_reply_to" =>
                                           array("type" =>
    "string",
    "index" => "no"),
                                       "f_type" =>
                                           array("type" =>
    "string",
                                       "f_status" =>
                                           array("type" =>
    "integer",
    "index" => "no"),
                                       "f_datetime" =>
                                       "f_userid" =>
    But I am
    elastic
    Same
    the
    situation.
    node :
       data : true
    gateway :
       type : fs
    index :
       analysis :
           analyzer :
               default :
                   type : custom
    stop]
    Thanks in advance
    H. Avetsyan
Hi Shay!
Below you can see the flow that I am passing through.
curl -XDELETE 'http://localhost:9200/test'
curl -XPUT 'http://localhost:9200/test'
curl -XPUT "http://localhost:9200/test/type1/_mapping" -d '{ "type1" :
{ "properties" : { "field1" : {"type" : "string", "index" : "no"},
"field2" : {"type" : "string", "index" : "analyzed"} } } }'
curl -XPUT 'http://localhost:9200/test/type1/1' -d '{ field1: "edo1",
field2: "aaa" }'
curl -XPUT 'http://localhost:9200/test/type1/2' -d '{ field1: "edo2",
field2: "bbb" }'
curl -XPUT 'http://localhost:9200/test/type1/3' -d '{ field1: "edo3",
field2: "ccc" }'
curl -XGET 127.0.0.1:9200/test/_search -d '{"query":{"query_string":
{"query":"edo1"}}}'
The last search line returns the first document, but it has type
"filed1" that created as "index":"no". This is the actual problem.
work?
Best regards,
H.Avetisyan
the
it
out.
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
Then you are searching by default on the _all field, clinton pointed out
that when setting index : "no", it still gets included in _all.
On Mon, Aug 22, 2011 at 9:02 AM, hamazasp.avetisyan <
Hi Shay!
field2: "aaa" }'
field2: "bbb" }'
field2: "ccc" }'
{"query":"edo1"}}}'
not
work?
Best regards,
H.Avetisyan
the
the
to
the
the
check
it
out.
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
am
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
Thank you !! It works !!
Hi Shay!
curl -XPUT 'http://localhost:9200/test/type1/1'-d '{ field1: "edo1",
field2: "aaa" }'
curl -XPUT 'http://localhost:9200/test/type1/2'-d '{ field1: "edo2",
field2: "bbb" }'
curl -XPUT 'http://localhost:9200/test/type1/3'-d '{ field1: "edo3",
field2: "ccc" }'
{"query":"edo1"}}}'
not
work?
Best regards,
H.Avetisyan
the
the
to
the
the
check
it
out.
structure of data.
array(
"f_id" =>
"f_from" =>
"f_subject" =>
"f_body" =>
"f_reply_to" =>
"index" => "no"),
"f_type" =>
"f_status" =>
"index" => "no"),
"f_datetime" =>
"f_userid" =>
am
situation.
node :
data : true
gateway :
type : fs
index :
analysis :
analyzer :
default :
type : custom
Thanks in advance
H. Avetsyan
