Index not found exception
Hi guys,
Iam new to elasticsearch. I have indexed a small file. I get an error when i try to query it through an API as below:
"errors": [
"message": "index_not_found_exception",
"locations": [
"line": 2,
"column": 3
"path": [
"gene"
"data": {
"gene": null
I am not able to figure out of the file has a problem, its content or the API connection. Is there a way to figure this out?
Mamta
Which API are u using? How do you know indexing was successful? Can you share code you are using to query?
Also post output of
curl http://localhost:9200/_cat/indices
