Index.query.bool.max_clause_count Setting and TermsQueryParser
In issue #482 (https://github.com/elasticsearch/elasticsearch/issues/
482), Shay mentioned to set the property
'index.query.bool.max_clause_count' in order to raise the max clause
count for a lucene bool query. I've tried to set this property but it
doesn't seem to be persisted. Am I doing something wrong? Here's what
I'm doing: https://gist.github.com/1019762
When I do get around to setting this property, will it fix a Lucene
TooManyClauses error w/ the TermsQueryParser if I have over 1024
terms? I noticed that the setting is applied for the the
BoolQueryParser only from that issue (482).
Any help or thoughts would be greatly appreciated.
Thanks,
JR
You should provide the property in the following way :
curl -XPUT "http://localhost:9200/_settings" -d '
"index" : {
"query" : {
"bool" : {
"max_clause_count": 2048
Best,
Stéphane
2011/6/10 Joe Rawlings joseph.rawlings@gmail.com:
In issue #482 (Issues · elastic/elasticsearch · GitHub
Thanks,
JR
That's essentially the same thing I was doing. Still, I tried it and
the property didn't show up when I retrieved the settings. :confused:
"index" : {
"query" : {
"bool" : {
Best,
Stéphane
2011/6/10 Joe Rawlings joseph.rawli...@gmail.com:
I'm doing:https://gist.github.com/1019762
Thanks,
JR
I think that you should remove your index before sending settings.
Try this :
curl -XDELETE "http://localhost:9200/myindex" -d ' {}'
curl -XPUT "http://localhost:9200/myindex/_settings" -d '
"index" : {
"query" : {
"bool" : {
Hope this helps.
David :wink:
"index" : {
"query" : {
"bool" : {
Best,
Stéphane
Thanks,
JR
You can't set this setting "on the fly", since it gets applied when an index gets created.
Try this :
"index" : {
"query" : {
"bool" : {
Hope this helps.
David :wink:
Le 11 juin 2011 à 16:30, Joe Rawlings <joseph.rawlings@gmail.com (mailto:joseph.rawlings@gmail.com)> a écrit :
On Jun 11, 12:51 am, Stéphane Raux <stephane.r...@gmail.com (http://gmail.com)> wrote:
"index" : {
"query" : {
"bool" : {
Best,
Stéphane
2011/6/10 Joe Rawlings <joseph.rawli...@gmail.com (http://gmail.com)>:
Thanks,
JR
Cool, so I started reindexing my data with the
"index.query.bool.max_clause_count" set to 8192 and retried the query
that was causing the issue before. The same 'maxClauseCount is set to
1024' error showed up again. I put a breakpoint in the BoolQueryParser
and reran the query but nothing was hit. Any thoughts?
You don't need to reindex your data for that... . You could have closed and reopened your index for example. Or just set it in the elasticsearch.yml file. This setting is tricky, since its a static one (Lucene wise). So, I suggest setting it in the elasticsearch.yml file so it will always apply.
On Jun 10, 2:03 pm, Joe Rawlings <joseph.rawli...@gmail.com (http://gmail.com)> wrote:
Perfect, thank you
