All,
I am using elastic search version 0.19.4.
My requirement is to index the documents to a particular node and exclude
the rest of the nodes. Hence for multiple index requests. I would manage
which node the index should go to.
I tried the index routing mechanism but this does not seem to work with the
version mentioned above.
My test scenario;
1- started 3 ES nodes with node.tag: node1 , node.tag: node2 and node.tag:
node3 respectively.
2- I am using transport client to communicate the ES nodes.
3- I am using bulk index api to index the document.
4- None of the api available with Transport Client or Bulk request allow me
to hook the index.routing.allocation.include.tag orindex.routing
.allocation.exclude.tag.
5- Used UpdateSettingsRequest but it did not help either.
Sample code;
Settings s =
ImmutableSettings.settingsBuilder().put("testRouting").put("client.transport.sniff",
true).build();
TransportClient tc = new TransportClient(s);
tc.addTransportAddress(new
InetSocketTransportAddress("192.168.1.2", 9300));
InetSocketTransportAddress("192.168.1.2", 9301));
InetSocketTransportAddress("192.168.1.2", 9302));
UpdateSettingsRequest updateSettings = new
UpdateSettingsRequest();
HashMap<String, String> hashMap = new HashMap<String,
String>();
hashMap.put("index.routing.allocation.include.tag","node1"
hashMap.put("index.routing.allocation.exclude.tag","node2,node3"
hashMap.put("index.routing.allocation.total_shards_per_node",
"3");
String[] indices = new String[1];
indices[0] ="test*";
updateSettings.indices(indices);
updateSettings.settings(hashMap);
while (true) {
BulkRequestBuilder bulkRequest = tc.prepareBulk();
for (int i = 0; i < 3; i++) {
System.out.println( "------" + i);
bulkRequest.add(Requests.indexRequest("test"
i).type("type").source("field", "value"));
} bulkRequest.execute().actionGet(); }
Please suggest if I am missing something or the feature is not in 0.19.4.
If not how can I make to work with the available scenario.
Amit
I have tried the other option as well to update the settings via
client>admin>indices>updatesettings but even than I am not able to rout;
UpdateSettingsRequest updateSettings = new UpdateSettingsRequest();
String>();
"3");
String[] indices = new String[3];
indices[0] ="test0";
indices[1] ="test1";
indices[2] ="test2";
tc.admin().indices().updateSettings(updateSettings).actionGet();
