I think I made a mistake, curator wouldn't work and I went to /elasticeasrch/nodes/0/indices and I deleste all indices !!
Now I can't receive any logs
If you only have a single node and no replicas, nor any snapshot to restore from, that would indeed be a problem. What is the status of your cluster? Have you restarted it?
[root@frghcslnetv12 elasticsearch]# systemctl status elasticsearch.service
● elasticsearch.service - Elasticsearch
Loaded: loaded (/usr/lib/systemd/system/elasticsearch.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2018-06-21 10:59:58 CEST; 41min ago
Docs: http://www.elastic.co
Process: 60597 ExecStartPre=/usr/share/elasticsearch/bin/elasticsearch-systemd-pre-exec (code=exited, status=0/SUCCESS)
Main PID: 60599 (java)
Tasks: 50
CGroup: /system.slice/elasticsearch.service
└─60599 /bin/java -Xms2g -Xmx2g -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -server -Xss1m...
Jun 21 10:59:58 frghcslnetv12 systemd[1]: Starting Elasticsearch...
Jun 21 10:59:58 frghcslnetv12 systemd[1]: Started Elasticsearch.
Yes I restart it, and I have just one node
!!! PLEASE HELP
If you have deleted all the data from the file system and have no snapshot to restore from, it is lost. Is the node running?
How can I know ?
What is the output of the cluster health API?
[root@frghcslnetv12 elasticsearch]# curl XGET "http://127.0.0.1:9200/_cluster/health"
curl: (6) Could not resolve host: XGET; Unknown error
{"cluster_name":"graylog","status":"green","timed_out":false,"number_of_nodes":1,"number_of_data_nodes":1,"active_primary_shards":4,"active_shards":4,"relocating_shards":0,"initializing_shards":0,"unassigned_shards":0,"delayed_unassigned_shards":0,"number_of_pending_tasks":0,"number_of_in_flight_fetch":0,"task_max_waiting_in_queue_millis":0,"active_shards_percent_as_number":100.0}[root@frghcslnetv12 elasticsearch]#
Looks like it is up and running:
"cluster_name": "graylog",
"status": "green",
"timed_out": false,
"number_of_nodes": 1,
"number_of_data_nodes": 1,
"active_primary_shards": 4,
"active_shards": 4,
"relocating_shards": 0,
"initializing_shards": 0,
"unassigned_shards": 0,
"delayed_unassigned_shards": 0,
"number_of_pending_tasks": 0,
"number_of_in_flight_fetch": 0,
"task_max_waiting_in_queue_millis": 0,
"active_shards_percent_as_number": 100.0
As there are indices in the cluster it may even be receiving data again.
[root@frghcslnetv12 elasticsearch]# df -kh
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vgroot-root 22G 9.6G 12G 46% /
devtmpfs 3.8G 0 3.8G 0% /dev
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 3.9G 28M 3.8G 1% /run
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/sda1 1014M 208M 807M 21% /boot
/dev/mapper/vgdata-lvdata 196G 265M 188G 1% /data
tmpfs 781M 0 781M 0% /run/user/0
My path.data is : /data/elasticsearch
And filebeat is sending data but I m not receveing them !!
1% /data !!
What is the output of the cat indices API?
[root@frghcslnetv12 elasticsearch]# curl XGET "http://127.0.0.1:9200/_cat/indices/twi*?v&s=index"
health status index uuid pri rep docs.count docs.deleted store.size pri.store.size
What does curl -XGET "http://127.0.0.1:9200/_cat/indices give? What indices do you have in the cluster?
[root@frghcslnetv12 elasticsearch]# curl -XGET "http://127.0.0.1:9200/_cat/indices"
green open graylog_0 XYAgOe9GSeGSMpv6vNEk5w 4 0 347825 0 547.1mb 547.1mb
Looks like Graylog is able to write data. Are you expecting any other indices in the cluster?
The problème is the path.data is /data/elasticsearch
and logs are stored on : / (it will be full in few minutes !! )
So logs are not sent to : Elasticsearch
What does your elasticsearch.yml file look like?
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
# Before you set out to tweak and tune the configuration, make sure you
# understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: graylog
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
#node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
path.data: /data/elasticsearch
# Path to log files:
#path.logs: /path/to/logs
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
#network.host: 0.0.0.0
# Set a custom port for HTTP:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when new node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
#discovery.zen.ping.unicast.hosts: ["172.16.250.30"]
# Prevent the "split brain" by configuring the majority of nodes (total number of master-eligible nodes / 2 + 1):
#discovery.zen.minimum_master_nodes: 3
# For more information, consult the zen discovery module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
How did you install Elasticsearch? Where was that elasticsearch.yml file located?
cd /etc/elasticsearch/elasticsearch.yml
As far as I can see the file looks fine and is in the correct location, so I am not sure what is wrong. Has anything changed recently?
