HI there, i installed the K8s operator for 1.0.0-beta on my cluster. I attempted to install the default single node cluster using the Quick start guide. My K8s admin has so enforced resource limits so i had to explicitly add resources for my cluster, however the init container fails. Any help would be greatly appreciated. The stackset looks like
cat <<EOF | zkubectl apply -f -
   apiVersion: elasticsearch.k8s.elastic.co/v1beta1
   kind: Elasticsearch
   metadata:
     application: color-vector
   spec:
     version: 7.5.0
     nodeSets:
     - name: default
       count: 1
       config:
         node.master: true
         node.data: true
         node.ingest: true
         node.store.allow_mmap: false
       podTemplate:
         spec:
           initContainers:
           - name: elastic-internal-init-filesystem
             resources:
               requests:
                 memory: 1Gi
                 cpu: 1
               limits:
                 memory: 1Gi
                 cpu: 1
   EOF
The pod failed to initialize as the init container failed as below, Im not sure if its a volume mount problem or an incorrect user or permissions:
>$ kubectl logs color-vector-es-default-0 -c elastic-internal-init-filesystem
chroot: failed to run command '/usr/share/elasticsearch/bin/elasticsearch': No such file or directory
The pod and persistent volume claim description are here:
zkubectl describe pod color-vector-es-default-0
Namespace:          default
Priority:           0
PriorityClassName:  <none>
Node:               ip-XXX-XXX-XXX-XXX.eu-central-1.compute.internal/172.31.23.159
Start Time:         Wed, 18 Dec 2019 17:48:02 +0000
Labels:             common.k8s.elastic.co/type=elasticsearch
                    controller-revision-hash=color-vector-es-default-66b9c4cb6
                    elasticsearch.k8s.elastic.co/cluster-name=color-vector
Status:             Pending
Controlled By:      StatefulSet/color-vector-es-default
Init Containers:
  elastic-internal-init-filesystem:
    Container ID:   docker://d51d56c9d3298260f27cfcf93b48e7ef0932218f34576fb7d086488bc5f00798
    Image:          docker.elastic.co/elasticsearch/elasticsearch:7.5.0
    Image ID:       docker-pullable://docker.elastic.co/elasticsearch/elasticsearch@sha256:5d4f00b9a5f5f8e882b3301c401ce3bebe1fd09a45b4e70de3761056c76934c3
    Port:           <none>
    Host Port:      <none>
    State:          Terminated
      Reason:       Error
      Exit Code:    127
      Started:      Wed, 18 Dec 2019 18:09:18 +0000
      Finished:     Wed, 18 Dec 2019 18:09:18 +0000
    Last State:     Terminated
      Reason:       Error
      Exit Code:    127
      Started:      Wed, 18 Dec 2019 18:04:14 +0000
      Finished:     Wed, 18 Dec 2019 18:04:14 +0000
    Ready:          False
    Restart Count:  9
    Limits:
      cpu:     1
      memory:  1Gi
    Requests:
      cpu:     1
      memory:  1Gi
    Environment:
      POD_IP:                                           (v1:status.podIP)
      POD_NAME:                                        color-vector-es-default-0 (v1:metadata.name)
      _PLATFORM_DOCKER_IMAGE:                          docker.elastic.co/elasticsearch/elasticsearch:7.5.0
    Mounts:
      /mnt/elastic-internal/elasticsearch-config from elastic-internal-elasticsearch-config (ro)
      /mnt/elastic-internal/probe-user from elastic-internal-probe-user (ro)
      /mnt/elastic-internal/scripts from elastic-internal-scripts (ro)
      /mnt/elastic-internal/unicast-hosts from elastic-internal-unicast-hosts (ro)
      /mnt/elastic-internal/xpack-file-realm from elastic-internal-xpack-file-realm (ro)
      /usr/share/elasticsearch/bin from elastic-internal-elasticsearch-bin-local (rw)
      /usr/share/elasticsearch/config from elastic-internal-elasticsearch-config-local (rw)
      /usr/share/elasticsearch/config/http-certs from elastic-internal-http-certificates (ro)
      /usr/share/elasticsearch/config/transport-certs from elastic-internal-transport-certificates (ro)
      /usr/share/elasticsearch/data from elasticsearch-data (rw)
      /usr/share/elasticsearch/logs from elasticsearch-logs (rw)
      /usr/share/elasticsearch/plugins from elastic-internal-elasticsearch-plugins-local (rw)
Containers:
  elasticsearch:
    Container ID:
    Image ID:
    Ports:          9200/TCP, 9300/TCP
    Host Ports:     0/TCP, 0/TCP
    State:          Waiting
      Reason:       PodInitializing
    Ready:          False
    Restart Count:  0
    Limits:
      memory:  2Gi
    Requests:
      cpu:      25m
      memory:   2Gi
    Readiness:  exec [bash -c /mnt/elastic-internal/scripts/readiness-probe-script.sh] delay=10s timeout=5s period=5s #success=1 #failure=3
    Environment:
      NSS_SDB_USE_CACHE:                               no
      PROBE_PASSWORD_FILE:                             /mnt/elastic-internal/probe-user/elastic-internal-probe
      PROBE_USERNAME:                                  elastic-internal-probe
      READINESS_PROBE_PROTOCOL:                        https
      _PLATFORM_OPENTRACING_TAG_ARTIFACT:              docker.elastic.co/elasticsearch/elasticsearch:7.5.0
    Mounts:
Conditions:
  Type              Status
  Initialized       False
  Ready             False
  ContainersReady   False
  PodScheduled      True
Volumes:
  elasticsearch-data:
    Type:       PersistentVolumeClaim (a reference to a PersistentVolumeClaim in the same namespace)
    ClaimName:  elasticsearch-data-color-vector-es-default-0
    ReadOnly:   false
  elastic-internal-elasticsearch-bin-local:
    Type:    EmptyDir (a temporary directory that shares a pod's lifetime)
    Medium:
  elastic-internal-elasticsearch-config:
    Type:        Secret (a volume populated by a Secret)
    SecretName:  color-vector-es-default-es-config
    Optional:    false
  elastic-internal-elasticsearch-config-local:
    Medium:
  elastic-internal-elasticsearch-plugins-local:
    Medium:
  elastic-internal-http-certificates:
    SecretName:  color-vector-es-http-certs-internal
    Optional:    false
  elastic-internal-probe-user:
    SecretName:  color-vector-es-internal-users
    Optional:    false
  elastic-internal-scripts:
    Type:      ConfigMap (a volume populated by a ConfigMap)
    Optional:  false
  elastic-internal-transport-certificates:
    SecretName:  color-vector-es-transport-certificates
    Optional:    false
  elastic-internal-unicast-hosts:
    Optional:  false
  elastic-internal-xpack-file-realm:
    SecretName:  color-vector-es-xpack-file-realm
    Optional:    false
  elasticsearch-logs:
    Medium:
QoS Class:       Burstable
Node-Selectors:  <none>
Tolerations:     node.kubernetes.io/not-ready:NoExecute for 300s
                 node.kubernetes.io/unreachable:NoExecute for 300s
Events:
  Type     Reason                  Age                 From                                                     Message
  Warning  FailedScheduling        21m (x2 over 21m)   default-scheduler                                        pod has unbound immediate PersistentVolumeClaims
  Normal   Scheduled               21m                 default-scheduler                                        Successfully assigned default/color-vector-es-default-0 to ip-XXX-XXX-XXX-XXX.eu-central-1.compute.internal
  Normal   SuccessfulAttachVolume  21m                 attachdetach-controller                                  AttachVolume.Attach succeeded for volume "pvc-59bd0770-e4a1-487e-b5da-0c98da2a5690"
  Normal   Pulled                  19m (x5 over 21m)   kubelet, ip-XXX-XXX-XXX-XXX.eu-central-1.compute.internal  Container image "docker.elastic.co/elasticsearch/elasticsearch:7.5.0" already present on machine
  Normal   Created                 19m (x5 over 21m)   kubelet, ip-XXX-XXX-XXX-XXX.eu-central-1.compute.internal  Created container elastic-internal-init-filesystem
  Normal   Started                 19m (x5 over 21m)   kubelet, ip-XXX-XXX-XXX-XXX.eu-central-1.compute.internal  Started container elastic-internal-init-filesystem
  Warning  BackOff                 67s (x95 over 21m)  kubelet, ip-XXX-XXX-XXX-XXX.eu-central-1.compute.internal  Back-off restarting failed container
And the volume claim
zkubectl describe pvc elasticsearch-data-color-vector-es-default-0
Namespace:     default
StorageClass:  standard
Status:        Bound
Volume:        pvc-59bd0770-e4a1-487e-b5da-0c98da2a5690
               elasticsearch.k8s.elastic.co/statefulset-name=color-vector-es-default
Annotations:   pv.kubernetes.io/bind-completed: yes
               pv.kubernetes.io/bound-by-controller: yes
               volume.beta.kubernetes.io/storage-provisioner: kubernetes.io/aws-ebs
Finalizers:    [kubernetes.io/pvc-protection]
Capacity:      1Gi
Access Modes:  RWO
VolumeMode:    Filesystem
Events:
  Normal     ProvisioningSucceeded  22m   persistentvolume-controller  Successfully provisioned volume pvc-59bd0770-e4a1-487e-b5da-0c98da2a5690 using kubernetes.io/aws-ebs
Mounted By:  color-vector-es-default-0```
