Hi everyone,
We are currently troubleshooting intermittent log loss in a Logstash setup using the UDP input plugin and wanted to check if anyone in the community has faced similar behavior.
Current setup (genericized):
Source Systems → Load Balancer → Multiple Logstash Nodes (UDP input) → Downstream destinations
Observations:
Logs are generated successfully at the source side
Some logs intermittently do not appear downstream
No explicit errors are visible in Logstash logs
Behavior seems more noticeable after periods of inactivity / low traffic
Traffic is load balanced across multiple Logstash nodes
We understand UDP itself is connectionless and does not guarantee delivery, but we wanted to understand specifically from the Logstash/community perspective:
Has anyone observed UDP “timeout-like” behavior where logs stop appearing after idle periods?
Are there any known limitations or caveats with the Logstash UDP input plugin under intermittent traffic?
Has anyone implemented any “keepalive”-style approach for long-running low-frequency UDP sources?
Are there best practices when using UDP behind a load balancer with multiple Logstash nodes?
Additional troubleshooting already performed:
Comparing source-generated logs vs received logs
Forwarding logs in parallel to multiple destinations for correlation
Any recommendations, similar experiences, or tuning suggestions would be greatly appreciated.
Thanks in advance!
