I'm confused by this setting. I used to set this in elasticsearch.yml in v1.7 but now the setting move to index level setting. Does that means:
Per index can have a different value?
Let's say index abc put 1 and index xyz put 2
Any idea? Thanks a lot.
Here is my little experiment
Create two indices, abc and test, but put the different settings and then get http://localhost:9200/_settings from Elasticsearch with the following result.
#1. So what is the number that merge scheduler max thread count? 4 or 2 or 4+2?
#2. will merge policy actually different for both index?
"test": {
"settings": {
"index": {
"refresh_interval": "5s",
"number_of_shards": "1",
"provided_name": "test",
"merge": {
"scheduler": {
"max_thread_count": "4"
"policy": {
"segments_per_tier": "3",
"max_merge_at_once": "2",
"max_merged_segment": "10mb"
"creation_date": "1505384721746",
"number_of_replicas": "0",
"uuid": "etDLnuqVSeurnSP25j7CJw",
"version": {
"created": "5040099"
"abc": {
"settings": {
"index": {
"provided_name": "abc",
"merge": {
"scheduler": {
"max_thread_count": "2"
"policy": {
"creation_date": "1505402967991",
"uuid": "vvtnZTUMSOabDc-ShdUioA",
"version": {
