Is it possible to create two index for the same day using logstash templete
I am using logstash to send data elasticsearch on daily basis but the size of the indexes created is too large .that is why i want ot create two index for the same day.is it possible using logstash
This is typically handled by setting shards to a value that would get each shard to around 50G.
ILM is your future, it can rollover an index at size limit.
Can we do it like this for hourly logs
output{
elasticsearch{
index => index_name%{+YY.MM.dd.HH}
and if this is possible is there a way to do it for every 12 hours
Maybe it will be not ideal but you could do the following:
parse the date from @timestamp, and check if the hour in the timestamp is having a certain value.
grok {
#process the @timestamp
if [hour] >= 12 {
mutate {
add_field => {"index_rotator"=> "1"}
else {
mutate {
add_field => {"index_rotator"=> "2"}
so you can have a predictable:
output{
elasticsearch{
index => index_name%{+YY.MM.dd}-%{index_rotator}
Or just use the _ilm.
It is much better and this is for what it was designed to.
BTW. What is your usecase? To store some log data? To query that data you are loading?
yes it should work. I have tested with ww (weekly index) and it worked
Thanks @pastechecker it may be not ideal but for now it will serve the purpose.Meanwhile i will try to find if there is a better way
Hey @elasticforme Can you show me what index pattern you used for weekly index
in output section
index => "resource-%{+YYYY.ww}"
or you can use xxxx.ww
Follow this discussion
https://discuss.elastic.co/t/solved-weekly-indexes-instead-of-daily/56871
