Is it possible to specify "path" in multi_field mapping per field not per
entire property?
Example: I would like to map Vendor name property in multiple ways - edge
n-grammed for, shingled, not analyzed plus I want to include it into
"my_all" field
First three mapped fields I would like to be named as vendor.name.ngramm,
vendor.name.shingle, vendor.name.notanalyzed while the last one must be
called my_all so I can combine several properties into it.
I could use "jsut_name" and give my first three fields full names
( vendor.name.ngramm etc) but it would be lot better if I could specify
path per mapped field instead.
In my case it is more important than in general as I am trying to generate
ES mapping file from my own annotated document metadata and having to
produce full (nested) property name within metadata transformation process
is rather a challenge
