Is it possible to "warm up" indexes with low volume?
I have an index with 9M documents, 1 shard and 1 replica that receives traffic very sporadically (less than 5 requests per hour). The ingestion rate of this index is less than 1/s
A recurring pattern is that query response times spikes to 500ms–1s or higher immediately after the index is accessed after a long time. However, when the index becomes "hot" (i.e., receives more frequent requests), response times decrease significantly to the expected range for an index of this size, typically around 10–20ms.
Is there any way to configure Elasticsearch to “always keep an index hot”?
In case it matters, I have full control of the clients and know exactly what the query patterns are
What about running your query from a crontab for example?
If you are running on cloud (Gold) or with a commercial license you might want to run this frequent query from Watcher. Using Search input | Elastic Docs for example.
Thank you for your response @dadoonet
This is an approach I’ve thought about but haven’t tested. Is this how it is usually solved?
My understanding has been that caches are specific to each query and value. Is this understanding wrong?
Would running a scheduled query with a fixed value be beneficial in this case?
In other words, are caches maintained at the index/field level, or are they specific to the combination of index, field, and value?
Also, one follow up question if you don’t mind @dadoonet
While designing this sort of “Warming”, should I run the query patterns that we have for these indexes or would a single match all do the trick?
You should run a typical query, multiple times. With the right field names.
If you are using a filter by date, I'd suggest to use non static values but something like to: now/d+1d from now/d-30d for example.
Don't forget to add yours aggs, sort... if any.
Have you set index.refresh_interval on this index? If so, how is it configured?
Yes, we are using 1s refresh interval.
Thanks for clarifying. I did try that and I did not see any significant improvements for the “organic” traffic, but it is possible that I just need to let it run for a longer period
Thanks, hmm, ok I think @dadoonet ‘s suggestion of running typical queries to warm things up is probably the simplest way forwards. It’s either that or start to work with profilers and other OS-level tooling to work out what exactly is slow about the first queries. If you want to go down that path, the first thing I’d check for is whether the host is doing something else with its filesystem cache, paging out all the data Elasticsearch needs, causing a bunch of page faults to bring it back into cache on the first query after the pause.
