Is there a quick and easy way to check if my node is running in compressed oop?
version 7.15.3
There should be a log entry on startup pointing this out I believe.
Thanks.
So no api for run time query?
The cluster has been running for more than 1 year.
I am not aware of any API that show this.
You can use the _nodes API for it.
GET _nodes/jvm?pretty
This will return information about the jvm on all nodes, one of the fields in the response is this:
"using_compressed_ordinary_object_pointers": "true"
If you want to check just a specific node you can pass it in the API.
GET _nodes/node-name-or-node-id/jvm?pretty
cool, thanks.
That works.
