Issue with metricbeat kibana module when using custom path for Kibana
My kibana setup uses
SERVER_PUBLICBASEURL = http://www.example.com/kibana
SERVER_BASEPATH = /kibana
SERVER_REWRITEBASEPATH = "true"
My metricbeat autodiscovery for the kibana module uses:
- condition:
    contains:
       kubernetes.annotations.app: kibana
  config:
  - module: kibana
    hosts: ["https://${data.host}:5601/kibana"]
But I am getting this in my metricbeat logs:
Error fetching data for metricset kibana.cluster_rules: invalid character '<' looking for beginning of value
As if metricbeat is hitting some HTML.
I can curl
https://www.example.com/kibana/api/status just fine.
I can also curl the pods ip directly from inside the cluster:
https://elastic:elastic@10.150.1.22:5601/kibana/api/status
Before modifying the Kibana path, metricbeats was pulling Kibana metrics normally.
Please try this.
hosts: ["https://${data.host}:5601]
And restart metricbeat. I hope it helps.
Sorry this does not work:
Error fetching data for metricset kibana.cluster_rules: HTTP error 404 in : 404 Not Found
Sorry for the late reply, I was out on holidays for a week.
Try without the (S) in your https. Use http and see it this works.
I have tls enabled in kibana.
Metricbeats is able to upload dashboards to kibana fine to
https://${KIBANA_HOSTS}:5601/kibana
