Issues with instllation Elasti 8.2 with apt. Certificate problems
After installing Elasticsearch 8.2 in Ubuntu 22.04 I have one problem when I try to connect via curl.
❯ curl --cacert /etc/elasticsearch/certs/http_ca.crt -u elastic:1iXGIbPASSWORDQLp6+rv https://localhost:9200
curl: (77) error setting certificate file: /etc/elasticsearch/certs/http_ca.crt
I've verified certs installed by apt.
root@abkrim-nox:~# ls -lisah /etc/elasticsearch/certs/
total 32K
32251211 4,0K drwxr-x--- 2 root elasticsearch 4,0K may 20 20:07 .
32250781 4,0K drwxr-s--- 4 root elasticsearch 4,0K may 20 20:44 ..
32251212 4,0K -rw-rw---- 1 root elasticsearch 1,9K may 20 20:07 http_ca.crt
32251215  12K -rw-rw---- 1 root elasticsearch 9,9K may 20 20:07 http.p12
32251214 8,0K -rw-rw---- 1 root elasticsearch 5,7K may 20 20:07 transport.p12
After see this, I tried (and It0s works)
❯ sudo curl --cacert /etc/elasticsearch/certs/http_ca.crt -u elastic:1iXGIbGHCFcknQLp6+rv https://localhost:9200
  "name" : "abkrim-nox",
  "cluster_name" : "elasticsearch",
  "cluster_uuid" : "E_d31aTxSaKlUIIQhOKZkw",
  "version" : {
    "number" : "8.2.0",
    "build_flavor" : "default",
    "build_type" : "deb",
    "build_hash" : "b174af62e8dd9f4ac4d25875e9381ffe2b9282c5",
    "build_date" : "2022-04-20T10:35:10.180408517Z",
    "build_snapshot" : false,
    "lucene_version" : "9.1.0",
    "minimum_wire_compatibility_version" : "7.17.0",
    "minimum_index_compatibility_version" : "7.0.0"
I think is an issue with permission of deployed certificates by post script install of a deb package.
What is the way to correct this?
If you want to connect to Elasticsearch from your own user and use this cert, generally you would import the certificate into the local or system store so it can be read there.
