System OS:  Ubuntu 14.04.4 LTS
#java -version:
java version "1.8.0_101"
Java(TM) SE Runtime Environment (build 1.8.0_101-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.101-b13, mixed mode)
I install Logstash just following 3 command:
#wget -qO - https://packages.elastic.co/GPG-KEY-elasticsearch | sudo apt-key add -
#echo "deb https://packages.elastic.co/logstash/5.0/debian stable main" | sudo tee -a /etc/apt/sources.list
#apt-get update && apt-get install logstash
Reply:
Selecting previously unselected package logstash.
(Reading database ... 105309 files and directories currently installed.)
Preparing to unpack .../logstash_1%3a5.0.0~alpha4-1_all.deb ...
Unpacking logstash (1:5.0.0~alpha4-1) ...
Setting up logstash (1:5.0.0~alpha4-1) ...
Using provided startup.options file: /etc/logstash/startup.options
Sending all logs to /tmp/tmp.v9CVeNj21D
Successfully created system startup script for Logstash
But I don't see logstash auto script file in /etc/init.d/ directory
I enter /usr/share/logstash directory and command this
bin/logstash -e 'input { stdin { } } output { stdout {} }'
Reply:
--- jar coordinate com.fasterxml.jackson.core:jackson-annotations already loaded with version 2.7.1 - omit version 2.7.0
--- jar coordinate com.fasterxml.jackson.core:jackson-databind already loaded with version 2.7.1 - omit version 2.7.1-1
Logstash has a new settings file which defines start up time settings. This file is typically located in $LS_HOME/config or /etc/logstash. If you installed Logstash through a package and are starting it manually please specify the location to this settings file by passing in "--path.settings=/path/.." in the command line options {:level=>:warn}
Failed to load settings file from "path.settings". Aborting... {"path.settings"=>"/usr/share/logstash/config", "exception"=>Errno::ENOENT, "message"=>"No such file or directory - /usr/share/logstash/config/logstash.yml", :level=>:fatal}
cd /usr/share/logstash/bin/
./logstash
same reply
./system-install
Sending all logs to /tmp/tmp.4R6kewbM4r
cat /var/log/logstash/logstash.log
{:timestamp=>"2016-08-01T12:41:57.063000+0600", :message=>"SIGTERM received. Shutting down the agent.", :level=>:warn}
{:timestamp=>"2016-08-01T12:41:57.072000+0600", :message=>"stopping pipeline", :id=>"main", :level=>:warn}
{:timestamp=>"2016-08-01T12:41:57.750000+0600", :message=>"Pipeline main has been shutdown"}
{:timestamp=>"2016-08-01T12:43:00.610000+0600", :message=>"Pipeline main started"}
#cat /var/log/logstash/logstash.err
#cat /var/log/logstash/logstash.stdout
{:timestamp=>"2016-08-01T12:42:58.711000+0600", :message=>"Logstash has a new settings file which defines start up time settings. This file is typically located in $LS_HOME/config or /etc/logstash. If you installed Logstash through a package and are starting it manually please specify the location to this settings file by passing in "--path.settings=/path/.." in the command line options", :level=>:warn}
{:timestamp=>"2016-08-01T12:42:58.725000+0600", :message=>"Failed to load settings file from "path.settings". Aborting...", "path.settings"=>"/usr/share/logstash/config", "exception"=>Errno::ENOENT, "message"=>"No such file or directory - /usr/share/logstash/config/logstash.yml", :level=>:fatal}
my logstash configuration file
#vim /etc/logstash/conf.d/02-beats-input.conf
beats {
port => 5044
ssl => true
ssl_certificate => "/etc/pki/tls/certs/logstash-forwarder.crt"
ssl_key => "/etc/pki/tls/private/logstash-forwarder.key"
#vim /etc/logstash/conf.d/10-syslog-filter.conf
if [type] == "syslog" {
grok {
  match => { "message" => "%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:\[%{POSINT:syslog_pid}\])?: %{GREEDYDATA:syslog_message}" }
  add_field => [ "received_at", "%{@timestamp}" ]
  add_field => [ "received_from", "%{host}" ]
syslog_pri { }
date {
  match => [ "syslog_timestamp", "MMM  d HH:mm:ss", "MMM dd HH:mm:ss" ]
#vim /etc/logstash/conf.d/30-elasticsearch-output.conf
hosts => ["localhost:9200"]
sniffing => true
manage_template => false
what is my wrong?
Anybody help me kindly
