Logstash does not output to elastic , and now does not work at all
hi , i've benn dealing with a problem for 2 days now
i'm using logstash 2.3 on rhel VM
my logstash configurations worked just fine until yesterday:
i built another very simple configuration :
file {
type => "authlog15"
path => "/logstash/logs/auth2015-11-15-10.log"
sincedb_path => "/dev/null"
start_position => "beginning"
codec => multiline {
pattern => "^%{YEAR}"
negate => "true"
what => "next"
if [type] == "authlog15" {
            grok {
                    match => ["message", "%{GREEDYDATA:text}"]
hosts => ["hostname:9200"]
index => "authlog"
tried to run it with /opt/logstash/bin/logstash -f config.conf --debug
and i kept getting these messages with debug :
the same message kept coming up 3-4 times per second
tried to run the configuration with the service (put it in /etc/logstash/conf.d)
and the service crashed after 3 second (no logs - tried to run the service with debug and still no logs)
now al the other configurations that have worked before don't work now - the service always crashes
tried to change LS_HEAP_SIZE -still didn't work
tried booting the server twice - no help
tried to reinstall logstash - no help
what to do ????
the message:
Flushing buffer at interval {:instance=>"#<LogStash::Outputs::ElasticSearch::Buffer:0x26cf2d97 @operations_mutex=#<Mutex:0x2808c73e>, @max_size=500, @operations_lock=#<Java::JavaUtilConcurrentLocks::ReentrantLock:0x2c3746e7>, @submit_proc=#<Proc:0x3649f621@/opt/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-2.6.2-java/lib/logstash/outputs/elasticsearch/common.rb:57>, @logger=#<Cabin::Channel:0x5816e6e1 @metrics=#<Cabin::Metrics:0x4e80837a @metrics_lock=#<Mutex:0x91a324a>, @metrics={}, @channel=#<Cabin::Channel:0x5816e6e1 ...>>, @subscriber_lock=#<Mutex:0x701b25b6>, @level=:debug, @subscribers={12378=>#<Cabin::Subscriber:0x55842f79 @output=#<Cabin::Outputs::IO:0xd54cfe1 @io=#<IO:fd 1>, @lock=#<Mutex:0x24cb6d68>>, @options={}>}, @data={}>, @last_flush=2016-05-25 10:21:21 +0300, @flush_interval=1, @stopping=#<Concurrent::AtomicBoolean:0x140b3d7f>, @buffer=[], @flush_thread=#<Thread:0x60802760 run>>", :interval=>1, :level=>:debug, :file=>"logstash/outputs/elasticsearch/buffer.rb", :line=>"90", :method=>"interval_flush"}`indent preformatted text by 4 spaces`
Is ES up and running?
The problem was that i needed to put the ignore_older for more thanks 24h
