Logstash is reloading the same documents again and again from elasticsearch index
Hii.I am pulling documents from one Elasticsearch index into another Elasticsearch index using logstash.I am running logstash as a service by configuring "logstash.yml" file.The index from which I am pulling data,that index consist of 5 documents.But when I start logstash as a service it pulls the same data again and again into another index. I only want the 5 documents but logstash keeps on reloading the same data again and again.It is showing 10 documents and it constantly gets incremented i.e 15,20 and so on.
How to solve this issue?
This is my logstash configuration pipeline:-
                 hosts => ["http://ip:9200"]
                 user => "username"
                 password => "password"
                 tags => ["reviews"]
                 index => "reviews"
        if "reviews" in [tags] {
                      user => "username"
                      index => "test1"
This is the configuration of "logstash.yml" file
# Settings file in YAML
# Settings can be specified either in hierarchical form, e.g.:
#   pipeline:
#     batch:
#       size: 125
#       delay: 5
# Or as flat keys:
pipeline.batch.size: 125
pipeline.batch.delay: 5
# ------------  Node identity ------------
# Use a descriptive name for the node:
node.name: test
# If omitted the node name will default to the machine's host name
# ------------ Data path ------------------
# Which directory should be used by logstash and its plugins
# for any persistent needs. Defaults to LOGSTASH_HOME/data
path.data: /var/lib/logstash
# ------------ Pipeline Settings --------------
# The ID of the pipeline.
pipeline.id: main
# Set the number of workers that will, in parallel, execute the filters+outputs
# stage of the pipeline.
# This defaults to the number of the host's CPU cores.
# pipeline.workers: 2
# How many events to retrieve from inputs before sending to filters+workers
# pipeline.batch.size: 125
# How long to wait in milliseconds while polling for the next event
# before dispatching an undersized batch to filters+outputs
# pipeline.batch.delay: 50
# Force Logstash to exit during shutdown even if there are still inflight
# events in memory. By default, logstash will refuse to quit until all
# received events have been pushed to the outputs.
# WARNING: enabling this can lead to data loss during shutdown
# pipeline.unsafe_shutdown: false
# Set the pipeline event ordering. Options are "auto" (the default), "true" or "false".
# "auto" will  automatically enable ordering if the 'pipeline.workers' setting
# is also set to '1'.
# "true" will enforce ordering on the pipeline and prevent logstash from starting
# if there are multiple workers.
# "false" will disable any extra processing necessary for preserving ordering.
# pipeline.ordered: auto
# ------------ Pipeline Configuration Settings --------------
# Where to fetch the pipeline configuration for the main pipeline
path.config: /etc/logstash/conf.d
# Pipeline configuration string for the main pipeline
# config.string:
# At startup, test if the configuration is valid and exit (dry run)
# config.test_and_exit: false
# Periodically check if the configuration has changed and reload the pipeline
# This can also be triggered manually through the SIGHUP signal
# config.reload.automatic: false
# How often to check if the pipeline configuration has changed (in seconds)
# Note that the unit value (s) is required. Values without a qualifier (e.g. 60)
# are treated as nanoseconds.
# Setting the interval this way is not recommended and might change in later versions.
# config.reload.interval: 3s
# Show fully compiled configuration as debug log message
# NOTE: --log.level must be 'debug'
# config.debug: false
# When enabled, process escaped characters such as \n and \" in strings in the
# pipeline configuration files.
# config.support_escapes: false
# ------------ HTTP API Settings -------------
# Define settings related to the HTTP API here.
# The HTTP API is enabled by default. It can be disabled, but features that rely
# on it will not work as intended.
http.enabled: true
# By default, the HTTP API is bound to only the host's local loopback interface,
# ensuring that it is not accessible to the rest of the network. Because the API
# includes neither authentication nor authorization and has not been hardened or
# tested for use as a publicly-reachable API, binding to publicly accessible IPs
# should be avoided where possible.
http.host: 127.0.0.1
# The HTTP API web server will listen on an available port from the given range.
# Values can be specified as a single port (e.g., `9600`), or an inclusive range
# of ports (e.g., `9600-9700`).
http.port: 9600
# ------------ Module Settings ---------------
# Define modules here.  Modules definitions must be defined as an array.
# The simple way to see this is to prepend each `name` with a `-`, and keep
# all associated variables under the `name` they are associated with, and
# above the next, like this:
# modules:
#   - name: MODULE_NAME
#     var.PLUGINTYPE1.PLUGINNAME1.KEY1: VALUE
#     var.PLUGINTYPE1.PLUGINNAME1.KEY2: VALUE
#     var.PLUGINTYPE2.PLUGINNAME1.KEY1: VALUE
#     var.PLUGINTYPE3.PLUGINNAME3.KEY1: VALUE
# Module variable names must be in the format of
# var.PLUGIN_TYPE.PLUGIN_NAME.KEY
# modules:
# ------------ Cloud Settings ---------------
# Define Elastic Cloud settings here.
# Format of cloud.id is a base64 value e.g. dXMtZWFzdC0xLmF3cy5mb3VuZC5pbyRub3RhcmVhbCRpZGVudGlmaWVy
# and it may have an label prefix e.g. staging:dXMtZ...
# This will overwrite 'var.elasticsearch.hosts' and 'var.kibana.host'
# cloud.id: <identifier>
# Format of cloud.auth is: <user>:<pass>
# This is optional
# If supplied this will overwrite 'var.elasticsearch.username' and 'var.elasticsearch.password'
# If supplied this will overwrite 'var.kibana.username' and 'var.kibana.password'
# cloud.auth: elastic:<password>
# ------------ Queuing Settings --------------
# Internal queuing model, "memory" for legacy in-memory based queuing and
# "persisted" for disk-based acked queueing. Defaults is memory
# queue.type: memory
# If using queue.type: persisted, the directory path where the data files will be stored.
# Default is path.data/queue
# path.queue:
# If using queue.type: persisted, the page data files size. The queue data consists of
# append-only data files separated into pages. Default is 64mb
# queue.page_capacity: 64mb
# If using queue.type: persisted, the maximum number of unread events in the queue.
# Default is 0 (unlimited)
# queue.max_events: 0
# If using queue.type: persisted, the total capacity of the queue in number of bytes.
# If you would like more unacked events to be buffered in Logstash, you can increase the
# capacity using this setting. Please make sure your disk drive has capacity greater than
# the size specified here. If both max_bytes and max_events are specified, Logstash will pick
# whichever criteria is reached first
# Default is 1024mb or 1gb
# queue.max_bytes: 1024mb
# If using queue.type: persisted, the maximum number of acked events before forcing a checkpoint
# Default is 1024, 0 for unlimited
# queue.checkpoint.acks: 1024
# If using queue.type: persisted, the maximum number of written events before forcing a checkpoint
# queue.checkpoint.writes: 1024
# If using queue.type: persisted, the interval in milliseconds when a checkpoint is forced on the head page
# Default is 1000, 0 for no periodic checkpoint.
# queue.checkpoint.interval: 1000
# ------------ Dead-Letter Queue Settings --------------
# Flag to turn on dead-letter queue.
# dead_letter_queue.enable: false
# If using dead_letter_queue.enable: true, the maximum size of each dead letter queue. Entries
# will be dropped if they would increase the size of the dead letter queue beyond this setting.
# Default is 1024mb
# dead_letter_queue.max_bytes: 1024mb
# If using dead_letter_queue.enable: true, the interval in milliseconds where if no further events eligible for the DLQ
# have been created, a dead letter queue file will be written. A low value here will mean that more, smaller, queue files
# may be written, while a larger value will introduce more latency between items being "written" to the dead letter queue, and
# being available to be read by the dead_letter_queue input when items are are written infrequently.
# Default is 5000.
# dead_letter_queue.flush_interval: 5000
# If using dead_letter_queue.enable: true, the directory path where the data files will be stored.
# Default is path.data/dead_letter_queue
# path.dead_letter_queue:
# ------------ Metrics Settings --------------
# Bind address for the metrics REST endpoint
# http.host: "127.0.0.1"
# Bind port for the metrics REST endpoint, this option also accept a range
# (9600-9700) and logstash will pick up the first available ports.
# http.port: 9600-9700
# ------------ Debugging Settings --------------
# Options for log.level:
#   * fatal
#   * error
#   * warn
#   * info (default)
#   * debug
#   * trace
# log.level: info
path.logs: /var/log/logstash
# ------------ Other Settings --------------
# Where to find custom plugins
# path.plugins: []
# Flag to output log lines of each pipeline in its separate log file. Each log filename contains the pipeline.name
# Default is false
# pipeline.separate_logs: false
# ------------ X-Pack Settings (not applicable for OSS build)--------------
# X-Pack Monitoring
# https://www.elastic.co/guide/en/logstash/current/monitoring-logstash.html
#xpack.monitoring.enabled: false
#xpack.monitoring.elasticsearch.username: logstash_system
#xpack.monitoring.elasticsearch.password: password
#xpack.monitoring.elasticsearch.proxy: ["http://proxy:port"]
#xpack.monitoring.elasticsearch.hosts: ["https://es1:9200", "https://es2:9200"]
# an alternative to hosts + username/password settings is to use cloud_id/cloud_auth
#xpack.monitoring.elasticsearch.cloud_id: monitoring_cluster_id:xxxxxxxxxx
#xpack.monitoring.elasticsearch.cloud_auth: logstash_system:password
# another authentication alternative is to use an Elasticsearch API key
#xpack.monitoring.elasticsearch.api_key: "id:api_key"
#xpack.monitoring.elasticsearch.ssl.certificate_authority: [ "/path/to/ca.crt" ]
#xpack.monitoring.elasticsearch.ssl.truststore.path: path/to/file
#xpack.monitoring.elasticsearch.ssl.truststore.password: password
#xpack.monitoring.elasticsearch.ssl.keystore.path: /path/to/file
#xpack.monitoring.elasticsearch.ssl.keystore.password: password
#xpack.monitoring.elasticsearch.ssl.verification_mode: certificate
#xpack.monitoring.elasticsearch.sniffing: false
#xpack.monitoring.collection.interval: 10s
#xpack.monitoring.collection.pipeline.details.enabled: true
# X-Pack Management
# https://www.elastic.co/guide/en/logstash/current/logstash-centralized-pipeline-management.html
#xpack.management.enabled: false
#xpack.management.pipeline.id: ["main", "apache_logs"]
#xpack.management.elasticsearch.username: logstash_admin_user
#xpack.management.elasticsearch.password: password
#xpack.management.elasticsearch.proxy: ["http://proxy:port"]
#xpack.management.elasticsearch.hosts: ["https://es1:9200", "https://es2:9200"]
#xpack.management.elasticsearch.cloud_id: management_cluster_id:xxxxxxxxxx
#xpack.management.elasticsearch.cloud_auth: logstash_admin_user:password
#xpack.management.elasticsearch.api_key: "id:api_key"
#xpack.management.elasticsearch.ssl.certificate_authority: [ "/path/to/ca.crt" ]
#xpack.management.elasticsearch.ssl.truststore.path: /path/to/file
#xpack.management.elasticsearch.ssl.truststore.password: password
#xpack.management.elasticsearch.ssl.keystore.path: /path/to/file
#xpack.management.elasticsearch.ssl.keystore.password: password
#xpack.management.elasticsearch.ssl.verification_mode: certificate
#xpack.management.elasticsearch.sniffing: false
#xpack.management.logstash.poll_interval: 5s
# X-Pack GeoIP plugin
# https://www.elastic.co/guide/en/logstash/current/plugins-filters-geoip.html#plugins-filters-geoip-manage_update
#xpack.geoip.download.endpoint: "https://geoip.elastic.co/v1/database"
Every time that Elasticsearch query runs it will fetch the same documents. The Elasticsearch input does not have a way to maintain state. What you can do is to set the document id so that the documents are overwritten each time they are fetched. Check out the docinfo option.
Hii @Badger.Thanks for replying me.I will try this and let you know.
Hii@Badger.I have one query.The task of pulling logs from Elasticsearch index has to be done using jdbc input plugin in logstash.So how can I achieve this.Means which jdbc driver to use for pulling logs from an Elasticsearch index.Is there any jdbc driver or connector is available for Elasticsearch?
You are doing this in your configuration already.
You don't need JDBC to connect to ES. You use the Elasticsearch Input or Filter Plugin to do this.
If you are only looking to do this 1 time with the 5 documents why do you need a Logstash pipeline? I would think you would only want a pipeline if you want to periodically continuous integration.
Maybe the reindex api is more suitable for this use case.
Hii @aaron-nimocks.Thanks for your reply.I have 1000 documents in multiple sources i.e Elasticsearch,mongodb,mysql and textfile.All this data sources have 1000 documents in them.I want to pull all this 1000 documents from all this data sources periodically i.e this 1000 documents will won't get ingested at once.There will be a time interval of 1 hour.In every 1 hour logstash pipeline will run and it will check if there is any document there or not.To do this I have written logstash configuration pipeline for mysql and textfile.But I am not getting how to do this for pulling logs from Elasticsearch and mongodb.
