I am indexing elasticsearch via logstash but it is showing only document's fields with not null values.
Earlier I used to do this through transporter and it returns the null values as well. Also the mapping in both cases (transporter and logstash) is same.
Mongo --> Elasticsearch
eg - earlier response was [{"name":"xyz",city:null,"age":50,"additional_info":null}] now it is [{"name":"xyz","age":50}]
thanks for the quick response but I find that there is no output plugin like include_null_fields => true in logstash. can you suggest something further
This is not correct, Logstash will not remove any field by default.
Not sure where this come from, but there is no such option in the elasticsearch output in Logstash.
Please share your entire Logstash configuration and a sample of your message, also are you combining Logstash with any module of Filebeat for example?
mongodb {
uri => "mongo_uri"
placeholder_db_dir => "/usr/share/logstash/"
placeholder_db_name => "logstash_sqlite.db"
collection => "test"
batch_size => 50000
mutate {
remove_field => ["_id"]
hosts => ["http://ip:9200/"]
index => "test"
"_index": "test",
"_id": "U2DOaIkBXYO636wKiXYo",
"_score": 14.1151085,
"_ignored": [
"log_entry.keyword"
"_source": {
"mongo_id": "626943c4f7c76a6b553aa982",
"source_type": "__",
"img_link": "some source",
"logdate": "2022-04-27T13:23:16+00:00",
"uuid": "626943c4f7c76a6b553aa982",
"sources": "some source",
"full_name": "abc",
"designation": "xyz",
"profile_category": "__",
"log_entry": "{\"_id\"=>BSON::ObjectId('626943c4f7c76a6b553aa982'), \"created_date_time\"=>nil, \"profile_category\"=>\"abc\", \"Prefix\"=>nil, \"full_name\"=>\"abc\", \"first_name\"=>nil, \"last_name\"=>nil, \"native_name\"=>nil, \"birth_name\"=>nil, \"aliases\"=>[\"\"], \"gender\"=>nil, \"dob\"=>nil, \"age\"=>nil, \"birth_place\"=>nil, \"citizen_country\"=>[\"__\"], \"education\"=>nil, \"occupation\"=>nil, \"designation\"=>\"xyz\", \"positions_held\"=>nil, \"residence\"=>nil, \"sources\"=>\"something\", \"father\"=>nil, \"mother\"=>nil, \"siblings\"=>nil, \"spouse\"=>nil, \"children\"=>nil, \"relatives\"=>nil, \"wikipedia_link\"=>nil, \"img_link\"=>\"some link\"}",
"@timestamp": "2023-07-18T11:41:51.924906714Z",
"host": "2c2d8b232f8f",
"@version": "1"
