I have the exactly the same issue with you - no any output and can not view by Kibana . Can you show m your latest configuraiton file?
Below is my logstash conf file:
file {
path => "/test/table.csv"
start_position => "beginning"
ignore_older => 0
type => "core2"
sincedb_path => "/dev/null"
csv {
separator => ","
columns => ["Date", "Open", "High", "Low", "Close", "Volume", "Adj Closee"]
mutate { convert => ["High", "float"] }
mutate { convert => ["Open", "float"] }
mutate { convert => ["Low", "float"] }
mutate { convert => ["Close", "float"]}
mutate { convert => ["Volume", "float" ] }
action => "index"
hosts => "localhost"
index => "stock"
workers => 1
stdout { }
console:
spark:bin imsparkpan$ ./logstash -f logstash-file.conf -v
starting agent {:level=>:info}
starting pipeline {:id=>"main", :level=>:info}
Settings: Default pipeline workers: 4
Registering file input {:path=>["/test/table.csv"], :level=>:info}
Using mapping template from {:path=>nil, :level=>:info}
Attempting to install template {:manage_template=>{"template"=>"logstash-", "settings"=>{"index.refresh_interval"=>"5s"}, "mappings"=>{"default"=>{"_all"=>{"enabled"=>true, "omit_norms"=>true}, "dynamic_templates"=>[{"message_field"=>{"match"=>"message", "match_mapping_type"=>"string", "mapping"=>{"type"=>"string", "index"=>"analyzed", "omit_norms"=>true, "fielddata"=>{"format"=>"disabled"}}}}, {"string_fields"=>{"match"=>"", "match_mapping_type"=>"string", "mapping"=>{"type"=>"string", "index"=>"analyzed", "omit_norms"=>true, "fielddata"=>{"format"=>"disabled"}, "fields"=>{"raw"=>{"type"=>"string", "index"=>"not_analyzed", "doc_values"=>true, "ignore_above"=>256}}}}}, {"float_fields"=>{"match"=>"", "match_mapping_type"=>"float", "mapping"=>{"type"=>"float", "doc_values"=>true}}}, {"double_fields"=>{"match"=>"", "match_mapping_type"=>"double", "mapping"=>{"type"=>"double", "doc_values"=>true}}}, {"byte_fields"=>{"match"=>"", "match_mapping_type"=>"byte", "mapping"=>{"type"=>"byte", "doc_values"=>true}}}, {"short_fields"=>{"match"=>"", "match_mapping_type"=>"short", "mapping"=>{"type"=>"short", "doc_values"=>true}}}, {"integer_fields"=>{"match"=>"", "match_mapping_type"=>"integer", "mapping"=>{"type"=>"integer", "doc_values"=>true}}}, {"long_fields"=>{"match"=>"", "match_mapping_type"=>"long", "mapping"=>{"type"=>"long", "doc_values"=>true}}}, {"date_fields"=>{"match"=>"", "match_mapping_type"=>"date", "mapping"=>{"type"=>"date", "doc_values"=>true}}}, {"geo_point_fields"=>{"match"=>"", "match_mapping_type"=>"geo_point", "mapping"=>{"type"=>"geo_point", "doc_values"=>true}}}], "properties"=>{"@timestamp"=>{"type"=>"date", "doc_values"=>true}, "@version"=>{"type"=>"string", "index"=>"not_analyzed", "doc_values"=>true}, "geoip"=>{"type"=>"object", "dynamic"=>true, "properties"=>{"ip"=>{"type"=>"ip", "doc_values"=>true}, "location"=>{"type"=>"geo_point", "doc_values"=>true}, "latitude"=>{"type"=>"float", "doc_values"=>true}, "longitude"=>{"type"=>"float", "doc_values"=>true}}}}}}}, :level=>:info}
New Elasticsearch output {:class=>"LogStash::Outputs::ElasticSearch", :hosts=>["localhost"], :level=>:info}
Starting pipeline {:id=>"main", :pipeline_workers=>4, :batch_size=>125, :batch_delay=>5, :max_inflight=>500, :level=>:info}
Pipeline main started
