Hi all,
I'm working through a Logstash configuration which is parsing Cisco ISE log entries. I'm using multiline to collate entries into records and a grok filter coupled with a 'kv' filter which is mostly having the desired effect. There are potentially a large number of fields that are being processed by the 'kv' filter (around 100).
However, in the log messages, there are fields with the same name. e.g. Step and Stepdata. And what is happening is that instead of making these into individual fields, it is collating them into a list. Example from the original log messages.
StepData=3= TACACS.User, StepData=4= DEVICE.Device Type, StepData=6=SS_XX_User_PAP,
And using the following:
if [type] == "ise" {
kv {
source => "KVpairs"
field_split_pattern => ","
They are being populated in Elasticsearch as (for example):
" StepData": [
"3= TACACS.User",
"4= DEVICE.Device Type",
"6=SS_XX_User_PAP",
The problem is that I would like to have multiple fields based on format "Stepdata=3": value, "Stepdata=4": value rather than a single field using an array "Stepdata": [3= value, 4= another value]. Is this possible in this context?
Thanks in advance.
Neil
